Missing pyb, serial console and FTP problem.
Re: Missing pyb, serial console and FTP problem.
No jumpers delivered with my board either. No problem for me, but worth mentioning.
Dave
Dave
Today I already received the new expander module and my WiPy is running again. Thank you very much Daniel.danicampora wrote:No need to ship it back. Just PM me your name and I'll send another board to you.
Hello danicampora,
Were you able to test WinSCP?
Using WinSCP and FTP, I an not able to completely connect with the following message:
"Error getting name of current remote directory"
"Invalid response to PWD command"
The WinSCP screen shows it connected successfully then after trying to start the session I get the error above. Maybe there is a setting in WinSCP which needs to change, I'll experiment further.
On a better note, I was able to successfully connect with Putty/Telnet.
- danicampora
Is this also happening with the latest build? http://micropython.org/resources/firmwa ... 23a961.zip
Have you limited the number of data connections to 1? Is the FTP mode set to non-secure?
Yes, only Trying to connect with WinSCP, my Telnet connection is closed (if this is what you mean).Have you limited the number of data connections to 1?
It is set to no encryption (if this is what you mean).Is the FTP mode set to non-secure?
Version: Micro Python v1.4.6-21-gff736d6 on 2015-09-27; WiPy with CC3200
winscp doesn't work, I tried for a while with that too. I ended up having to download Filezilla instead.
I downloaded Filezilla and am still not able to connect. I get the message:
any suggestions?
my encryption setting is: "insecure"Status: Connecting to 192.168.1.1:21...
Error: Connection timed out after 20 seconds of inactivity
Error: Could not connect to server
any suggestions?
Are you connected to the wipy's wireless network?
Can you ping it?
Can you ping it?
I can connect with putty/telnet and I am connected via the wireless network.
I do NOT have the wipy connected via USB to the PC which is running putty or Filezilla.
And Yes I can ping it successfully via the command prompt wirelessly.
I've attached a screenshot of the settings that work for me. It took me a little while to get it sorted (started with winscp, same as you).
- ftp.jpg (114.2 KiB) Viewed 9585 times
