WDT with asyncio
vigorem
WDT with asyncio
Post by vigorem » Wed Aug 28, 2019 2:59 pm
I'm trying to implement a wdt using @peterhinch' excellent micropython-mqtt
He kindly indicated me a way to do so (on the git issue board) with the following:
import uasyncio as asyncio
from machine import WDT
async def do_wdt():
    tim = 300000
    wdt = WDT(timeout=tim)
        wdt.feed()
        await asyncio.sleep(tim // 10)  # Feed 10 times in timeout period (very conservative)
loop.create_task(do_wdt())
Unfortunatly I get an error "TypeError: function doesn't take keyword arguments" which I suspect comes from the
WDT(timeout=tim)
line.
How could I properly handle this WDT coroutine?
Many thanks,
Sébastien
vigorem
Re: WDT with asyncio
Post by vigorem » Wed Aug 28, 2019 3:38 pm
My shame, looks the issue is related to ESP8266 boards, used a custom WDT class found on the forum and looks good so far :
viewtopic.php?t=6376#p36275
Post by pythoncoder » Thu Aug 29, 2019 7:45 am
A quick experiment suggests that the ESP8266 WDT does not accept an argument. It seems to have a timeout of about 2 seconds. If it's a hardware WDT, so long as you can feed it frequently enough, it may be better than the software WDT.
If you want to try it I suggest creating a coroutine which instantiates it then loops forever feeding it (say) every 500ms. Start the coroutine when your code has connected to the server.
async def do_wdt():
    wdt = machine.WDT()
        await asyncio.sleep_ms(500)
        wdt.feed()
After connection:
The reason for waiting until after connection is that DNS in particular can block for longer than the WDT period.
