Using the tx/rx pins not for UART
Re: Using the tx/rx pins not for UART
Hi Brad,
I had some spare time an looked at your patch. The only thing I'm missing is where you set uart_os. That's in eps.debug I guess?
When you call esp.osdebug(None), it sets uart_os = -1.
Within the esp8266 port, search for uart_os_config in modesp.c and uart.c.
My patch extends the existing meaning of (-1) to fully decouple UART from REPL.
I'm not sure it's a good idea. For instance, I normally disable the debug messages (because I have no use for them and they are annoying), but still want to use the UART REPL...
Agree, overloading the semantics of esp.osdebug(None) is not a good long-term solution. There are several alternatives, the simplest of which might be to create a new constant, e.g. NO_UART_REPL=(-2) and invoke esp.osdebug(NO_UART_REPL) instead. It's on my todo list to evaluate a better API for this - just haven't had time to look at it lately. Would love to hear suggested alternatives!
Wouldn't it be smart to set a flag when micropython-serial opens the UART? This could work automatically.
I like that idea - explicitly initializing the UART would disconnect the REPL from it. Nicely avoids the issue of inventing an API to do this. The drawbacks would be no way to change the baud rate for REPL, no way to reverse the operation (get the REPL back) without reboot, and no mixing "raw" UART I/O with REPL. Perhaps we could add an 'ioctl' to switch the REPL flag in case someone wants to mix modes.
Hi Brad,
I'm not 100% sure but I think in the ESP-toolchain (or in the LUA-Firmware?!) there is a function to swap the pins of UART 0 to 2 other pins. That could maybe also used, just disconnect REPL when using the UART on the other to pins. But this is also a rather dirty hack
Reconnecting the REPL to the UART at with your patch at the moment works by just setting esp.osdebug(True). I've just tested this. So it should be no big deal to reconnect the REPL
Is see two ways:
Is there an REPL module that can be accesed from python? Then we coul make some connect(UART01)/disocnnec(UART01) function
Other way: REPL always connected to STDIO an somewhow connection/disconnection STDIO via sys (?!)
Is see two ways:
I also need to decouple the hardware uart from REPL
Perhaps something like the following in boot.py
import repl
with one of:
repl.telnet(port)
repl.web(port)
repl.serial(bps)
with say port/bps=0 stopping it? Not really important for me, I just want to choose the repl interface in boot.py
Now of course Wifi would have to be enabled/set up before the telnet/web versions...
import repl
with one of:
repl.telnet(port)
repl.web(port)
repl.serial(bps)
UP
I just would like to know what is the actual status of decoupling REPL from UART. This is fundamental to access peripherals that talk binary over uart/serial lines. I almost succeded to have meaningful replies from a PZEM004t power meter and the Control-C characters mess up with the communication (and just dont want to use C and Arduino sdk for esp!).
I also tried to apply the patch of @Brad (thank you btw), without success as probably that patch refers to to an old version of upython.
Besides I do think that a programmatic way to disable the repl from UART is needed (there always will be webrepl).
I solved it!
This is the ONE LINE solution.
One of the problem of my code was that 0x03 (the interrupt/control-c) was breaking the serial flow. It was not sufficient to trap the uart.read(), because the byte was missing from the serial line buffer. So the solution was simply to patch the uart.c routine in micropython to simply push it back into the serial line buffer. The Keyboard Event is still there and the try/except is simply to pass.
Now for those curious, this is the beast (yes, I am really proud of it!). It features:
- Power meter by means of the notorius PZEM004t (a hell of a chinese power meter)
- WeMos D1 Mini
- SSD1306 OLED Shield
- Independent Power Supply
- My own web server and code. Also it saves data on my personal IoT cloud server for nice graphics...
- A lot of work and swear and pain and joy... well you know
Now few things:
- WeMos but also Lolin V3 are pretty robust when it comes to voltages. PZEM004 works with TTL levels and WeMos/Lolin work with 3.3. I did NOT use any ttl converter. Even the resistor suggested somewhere (https://wifi-iot.com/?m=wiki&id=15) was more harmful than useful.
- You might say that I am very close to fry my chip but I am positive they won't
- I haven't seen any other binary data messing up with uart repl. I made a lot of trials disabling debug, sending Control-A to go in raw mode, but nothing was necessary.
- I didn't even connect to ground anything (). SO I guess there are some floating voltage around. But I think I will try to ground the circuits.
- I think the key to stability is the independent power supply.
. I didn't get the KWh but just followed the instructions from chinglish.
After all I think this works with some magic. For those interested I think I will put all on github... and no, I will not publish anything on instructables or hackster.. or anything. Just bewteen the few of this community and me...
--- esp8266/uart.c 2016-12-09 16:16:43.936221129 +0100
+++ esp8266/uart.c.original 2016-12-09 11:06:36.377927859 +0100
@@ -171,7 +171,6 @@
while (READ_PERI_REG(UART_STATUS(uart_no)) & (UART_RXFIFO_CNT << UART_RXFIFO_CNT_S)) {
uint8 RcvChar = READ_PERI_REG(UART_FIFO(uart_no)) & 0xff;
if (RcvChar == mp_interrupt_char) {
- ringbuf_put(&input_buf, RcvChar); // Erni T.
mp_keyboard_interrupt();
} else {
- WeMos D1 Mini
Now few things:
- screenshot
- 2016-12-11 21.29.19.jpg (66.53 KiB) Viewed 12752 times
- power meter
- 2016-12-11 21.29.19.jpg (148.02 KiB) Viewed 12752 times
