micropython-lib - "distributed" uPython standard library
Re: micropython-lib - "distributed" uPython standard library
I opened https://github.com/micropython/micropython-lib/issues/9 for this, will posts some ideas when I have time, and invite everyone to participate.
Awesome MicroPython list
I participated with some naive ideas from user perspective.
The micropython-lib looks to be very useful.
How do I get the libraries I need onto my micro python hardware? I'm assuming all this work for making this work with pip means I shouldn't have to just copy the files over, run them, see what dependencies I'm missing, and then copy over more files...
yes, is there any tutorial on how to get started with lib?
See http://forum.micropython.org/viewtopic.php?f=15&t=524jeffeb3 wrote: How do I get the libraries I need onto my micro python hardware? I'm assuming all this work for making this work with pip means I shouldn't have to just copy the files over, run them, see what dependencies I'm missing, and then copy over more files...
See MicroPython README, https://github.com/micropython/micropyt ... /README.md, search for "upip".kamikaze wrote:yes, is there any tutorial on how to get started with lib?
ok, so this is supposed to be only for unix port, right?pfalcon wrote:See MicroPython README, https://github.com/micropython/micropyt ... /README.md, search for "upip".kamikaze wrote:yes, is there any tutorial on how to get started with lib?
Initial support for running upip on networked bare-metal ports is available: http://forum.micropython.org/viewtopic.php?f=16&t=2544 . Each module in micropython-lib has is own requirements (some useful only for unix port, some universal, some require little memory, some more, some much).
The master repository of micropython-lib is now at https://github.com/pfalcon/micropython-lib . Some modules also require my fork of MicroPython, https://github.com/pfalcon/micropython , and there will be more such modules in the future. Majority of modules of course remain compatible with the upstream MicroPython.
Will changes to your micropython-lib / micropython eventually get merged into the corresponding micropython's repositories?
