New Lolin D32 Pro with 4MB PSRAM
Re: New Lolin D32 Pro with 4MB PSRAM
without the issue of the 1uF capacitor?
NodeMCU v0.9 / V1 / V2 / V3
WeMos D1 Mini
WeMos Lolin32 v1.0.0
WeMos Lolin D32 Pro V2
WeMos D1 Mini
That#s hard to tell without knowing the exact reason @mike teachman had. The obvious observation is, that in his set-up the timing of reset and GPIO0 do not match. GPIO0 low is too late with respect to the end of the reset pulse. But the reasons could be:
- GPIO0 is scanned too early (-> Lolin)
- the USB/UART bridge or the transistor circuit switche too slow (->Lolin)
- the controlling PC send the switch command too late (->PC)
Assuming that Wemos is testing their devices, I tend to the third explanation. But without testing it#s hard to tell.
So I bought them... somehow I have a feeling that was going to happen either way
I'm currently running into compile errors (viewtopic.php?f=18&t=5262) so I can't really test anything myself.
Is there a guide I can follow to setup Lolin with SD card support? I have only used MicroPython on boards without build-in SD card readers.
WeMos D1 Mini
WeMos D1 Mini
I just have tried and succeeded to use the built-in SD card on my Wemos LoLin32 Pro. It uses the sdcard.py script from the drivers/sdcard section and the following statements for mounting.
For the new Lolin D32 pro, the Pins for the SPI interface have to be adapted into:
You can also use the software SPI. In that case, the SPI device number is -1
import machine, sdcard, os
sd = sdcard.SDCard(machine.SPI(1, sck=machine.Pin(14), mosi=machine.Pin(15),
miso=machine.Pin(2)), machine.Pin(13))
os.mount(sd, "/sd")
sd = sdcard.SDCard(machine.SPI(1, sck=machine.Pin(18), mosi=machine.Pin(23),
miso=machine.Pin(19)), machine.Pin(4))
os.mount(sd, "/sd")
I bought 2 of them, somehow I'm unable to flash them...
root@patrick-X470-AORUS-ULTRA-GAMING:/home/patrick/Downloads# esptool.py --chip esp32 -p /dev/ttyUSB0 erase_flash
esptool.py v2.5.0
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Invalid head of packet (0x08)
WeMos D1 Mini
WeMos D1 Mini
Playing with the reset button while attempting to flash fixed it...
WeMos D1 Mini
WeMos D1 Mini
That is the reset problem mentioned above. You can also tie GPIO0 to GND, then push reset and then start the upload. That is reproducibly.
Well this probably indicates there is a hardware problem with the auto boot select on this board.
This is surprising as I have built over 20 boards using the Wrover module and a CP2014 USB serial convert and just a standard MMBT2222A transistor and 10k pullups on the RTS and DTR lines and every time the auto boot select worked perfectly.
I came here to ask about exactly this on the D32 Pro - if I enter your code from the REPL without a micro SD card, I get an error back that says "No SD Card" - as expected. If I insert the SD card however I get a new error that says "SPI Busy" - any idea why this might be? SD is formatted to FAT32. - Am I missing something?Roberthh wrote: ↑Sun Sep 16, 2018 9:31 amI just have tried and succeeded to use the built-in SD card on my Wemos LoLin32 Pro. It uses the sdcard.py script from the drivers/sdcard section and the following statements for mounting.For the new Lolin D32 pro, the Pins for the SPI interface have to be adapted into:Code: Select all
import machine, sdcard, os sd = sdcard.SDCard(machine.SPI(1, sck=machine.Pin(14), mosi=machine.Pin(15), miso=machine.Pin(2)), machine.Pin(13)) os.mount(sd, "/sd")
You can also use the software SPI. In that case, the SPI device number is -1Code: Select all
import machine, sdcard, os sd = sdcard.SDCard(machine.SPI(1, sck=machine.Pin(18), mosi=machine.Pin(23), miso=machine.Pin(19)), machine.Pin(4)) os.mount(sd, "/sd")
Using software SPI seems to work ok, I can browse the files on the sd card with os.listdir()
Grow something!
