ESP32 and LoRa
Barni
Re: ESP32 and LoRa
Post by Barni » Mon Dec 10, 2018 8:43 pm
Hello Robert,
You write that with a revision> 0 SPRAM is used.
In which file will this query take place.
I want to connect the SX1276 different, in which file I set the GPIO ports.
I would like to compile my own version.
Re: ESP32 and LoRa
Post by Roberthh » Mon Dec 10, 2018 9:21 pm
This is not a single place. There is a call to esp_get_revision() and esp_chip_info() in various places. You must change all places where esp_get_revision() and esp_chip_info() is called and hard code the '0' branch. Grep will tell you the places. The relevant files are main.c and mpthreadport.c and mptask.c. Maybe making a wrapper is more elegant.
But I abandoned that approach to use Pycom firmware on generic ESP32 devices. It was a nice exercise, but not of reasonable value. After all, WiPy's are not that expensive and of sound quality.
uCTRL
Re: ESP32 and LoRa
Post by uCTRL » Tue Dec 11, 2018 3:23 am
https://pycom.io/webshop/
You must have shares in Pycom or get paid a commission.
Re: ESP32 and LoRa
Post by Roberthh » Tue Dec 11, 2018 6:18 am
Not at all. But I had quite a few troubles with cheap crap. Of the 6 or so generic ESP32 boards only the Sparkfun device works without problems. At that one is in the price range of a WiPy. The other five (Wemos) work more or less. Two of them required physical rework (bad soldering), another one is crashing always after a few minutes. I did not have problems like these with devices from Adafruit, Pycom, Sparkfun. So that's my personal experience & opinion.
Edit: Similar experience with genuine Pyboards (reliable) and Pyboard clones (not reliable).
Edit2: Additionally it is ongoing work to keep your "special" build in sync with the mainline. You might get tired to do this after a while. But, as said, doing that port once is a good learning exercise.
Bernd67
Re: ESP32 and LoRa
Post by Bernd67 » Tue Dec 18, 2018 8:43 pm
was somebody able to make Loboris Lora example work? It can be found in https://github.com/loboris/MicroPython_ ... mples/lora. Unfortunately I wasn‘t able to make it run.
Currently the only way for me to use lora with micropython on ESP32 is this solution https://github.com/MZachmann/LightLora_MicroPython - but that doesn‘t support TTN. Maybe we could use this and add the TTN-Part?
mattyt
Re: ESP32 and LoRa
Post by mattyt » Wed Dec 19, 2018 2:51 am
Might be worth mentioning that Adafruit recently published an updated article about Using LoraWAN and The Things Network with CircuitPython, along with a CircuitPython library, TinyLoRa, that can control RFM9x devices. It only supports ABP, not OTAA, but I expect this will come in time.
It looks trivial to convert to MicroPython.
Hopefully this is useful to someone?
I know that there is a MicroPython meetup group in Perth, Australia that is looking to extend this library too...
fantasticdonkey
Re: ESP32 and LoRa
Post by fantasticdonkey » Sat Apr 20, 2019 8:01 pm
[quote=mattyt post_id=32724 time=1545187882 user_id=2488]
Might be worth mentioning that Adafruit recently published an updated article about [url=https://learn.adafruit.com/using-lorawa ... n/overview]Using LoraWAN and The Things Network with CircuitPython[/url], along with a CircuitPython library, [url=https://github.com/adafruit/Adafruit_Ci ... n_TinyLoRa]TinyLoRa[/url], that can control RFM9x devices. It only supports ABP, not OTAA, but I expect this will come in time.
[/quote]
Thanks for the suggestion. This is exactly what I did in the end to allow MicroPython running on ESP32 to perform unconfirmed data up to a TTN LoRa gateway. As is the case with the [url=https://github.com/adafruit/Adafruit_Ci ... n_TinyLoRa]Adafruit CircuitPython TinyLora library[/url] this has been forked from, it only works with node in ABP Activation Method.
https://github.com/fantasticdonkey/uLoRa
I've tested this in the south of the UK, against a number of publicly available TTN gateways, using a HelTec Automation ESP32 LoRa development board V2 (equipped with a Semtech SX1276).
apois
Re: ESP32 and LoRa
Post by apois » Sat Sep 28, 2019 11:57 am
Hi - are there any updated recommendations for pure Micropython Lora libraries - are any of the ones described above "stable" (loboris/MZachmann/Wei1234c)?
I tried a Lopy a year or two ago and had a few issues with timings in the Lora firmware and hardware (deep sleep) (although I think Pycom have resolved these on newer devices). I've now got hold of a Heltec ESP32 with lora and would like to try again.
I think I only need ABP auth support. It would be nice to be able to use a pure Micropython driver so that I can keep up with latest ESP32 Micropython builds and just drop the driver in to projects when needed, as it's just an SPI device.
Glagnar
Re: ESP32 and LoRa
Post by Glagnar » Sat Oct 24, 2020 10:30 pm
I am using this library - works pretty well.
https://github.com/lemariva/uPyLoRaWAN
lposada
Re: ESP32 and LoRa
Post by lposada » Thu Jun 10, 2021 9:02 pm
I'm using that library, but the downlink doesn't works. did it work for you?
