ImportError: no module named 'upower'
Philosophix
Post by Philosophix » Sat Jan 19, 2019 12:50 pm
I'm trying to use the BkpRAM from the upower module (https://github.com/peterhinch/micropyth ... /UPOWER.md) but I'm getting the following error:
File "main.py", line 6, in <module>
MicroPython v1.9.1 on 2017-06-11; PYBv1.1 with STM32F405RG
Any ideas?
Philosophix
Re: ImportError: no module named 'upower'
Post by Philosophix » Thu Jan 24, 2019 9:22 am
Doesn't anyone have a clue?
Post by Roberthh » Thu Jan 24, 2019 11:21 am
What exactly did you try. Without showing the code that failed almost no-one can help you.
Post by pythoncoder » Thu Jan 24, 2019 6:19 pm
You need to copy upower.py to the Pyboard: to the SD card if you're using one, otherwise to the internal flash.
This applies to all user-contributed code: it isn't officially supported so needs to be installed before use.
