bought two of this boards
https://de.aliexpress.com/item/Ra-01-SX ... 4c4dchvsOj
and connected one to ESP32 DEVKIT V1 using your code from github and run the example 'DuplexCallback' code. Get no error messages. It seems to run fine.
Then I connected the second one to a ESP8266 board
https://de.aliexpress.com/item/1PCS-Wir ... st=ae803_4 and got at startup:
File "main.py", line 11, in <module>
File "test.py", line 41, in main
File "controller.py", line 64, in add_transceiver
File "sx127x.py", line 97, in init
Exception: Invalid version.
Print out the version it shows version is 0.
I exchanged this board to ESP32 and there is no error message. This tells me, the problem is not at the SX1278.
I double checked more than once my wiring and cannot find any fault.
Test runs with MicroPython v1.9.4-8-ga9a3caad0 on 2018-05-11 and with esp8266-20190125-v1.10. Both same result.
By the way on ESP32 I use also esp8266-20190125-v1.10.
Do you have any idea what could be wrong?
Regards
Kurt
