The 'machine' module on Raspberry Pi
ProudPagan
Post by ProudPagan » Tue Apr 23, 2019 3:37 pm
Does anyone know how to build the 'machine' module on a Raspberry Pi running Raspbian or Buildroot?
I know boochow has a bare metal version with SPI and I2C, but I need MicroPython to run inside Buildroot.
Re: The 'machine' module on Raspberry Pi
Post by pythoncoder » Tue Apr 23, 2019 5:40 pm
As I understand it buildroot has the option of installing a Linux kernel, filesystem and bootloader. If you plan to use it in that mode I'd try the official Unix build. However this does not support machine. Otherwise I guess you'll need to skip the Linux OS options and build one of the baremetal ports.
I think the options of accessing hardware directly and having an underlying Linux OS are mutually exclusive.
ProudPagan
Post by ProudPagan » Fri Apr 26, 2019 2:23 pm
There's a low level RPi C library at http://www.airspayce.com/mikem/bcm2835/index.html
I could not find anything like the Python RPi.GPIO modules so I am trying to get a MicroPython wrapper working on top of this:
https://github.com/hacksterous/micropyt ... /mpbcm2835
I have tested simple GPIO writes, and it seems to work
import mpbcm2835
mpbcm2835.init()
#select GPIO17 (RPi-2 pin-P1-11) as output
mpbcm2835.fsel(17, 1)
#write '1'
mpbcm2835.write(17, 1)
#delay of 1000 milliseconds
mpbcm2835.delay(1000)
#write '0'
mpbcm2835.write(17, 0)
Feel free to use.
Post by jimmo » Sat Apr 27, 2019 1:11 pm
Not sure if this is useful or not (or even a good idea), but depending on what you need from `machine` (e.g. just basic pin control), can you get by with filesystem access to sysfs-gpio? (Write the pin number to `/sys/class/gpio/export` then access `/sys/class/gpio/gpioN/value` )
(But the `mpbcm2835` module linked above looks heaps better :D )
Turbinenreiter
Post by Turbinenreiter » Sat Apr 27, 2019 5:34 pm
The CircuitPython HAL works on Raspberry Pi with Linux, its using CPython tough.
https://learn.adafruit.com/circuitpytho ... x/overview
Having the machine module on Raspberry Pi is definitely possible, but nobody wrote it yet.
pfalcon
Post by pfalcon » Tue Apr 30, 2019 7:58 pm
"machine" module for Unix port was written 3 years ago: https://github.com/pfalcon/micropython- ... ne/machine . Obviously, the amount of the code written so far is based on the needs of people who contributed to the module.
Awesome MicroPython list
kevinkk525
Post by kevinkk525 » Wed May 08, 2019 3:55 pm
import mpbcm2835
mpbcm2835.init()
#write '1'
#write '0'
Feel free to use.
This looks very promising and recent. But it doesn't conform to the typical machine.Pin interface so needs another wrapper around it to be compatible.
Kevin Köck
