Question: It there a way to detect, if the filesystem is already converted to LittleFS?
Think i found a way:
import flashbdev
import uos as os
uname = os.uname()
print(uname.machine, uname.release)
print('MicroPython', uname.version)
print()
print('flashbdev.size....:', flashbdev.size)
print('reserved sectors..:', flashbdev.bdev.RESERVED_SECS)
print('start sector......:', flashbdev.bdev.START_SEC)
print('sector size.......:', flashbdev.bdev.SEC_SIZE)
print('num blocks........:', flashbdev.bdev.NUM_BLK)
def filesystem_hex_dump(line_count=10, chunk_size=16):
buf = bytearray(chunk_size)
for block_num in range(line_count):
offset = block_num * chunk_size
print('%04x - %04x' % (offset, offset + chunk_size - 1), end=' - ')
flashbdev.bdev.readblocks(block_num, buf)
print(' '.join('%02x' % char for char in buf), end=' - ')
print(''.join(chr(char) if 32 < char < 177 else '.' for char in buf))
ESP module with ESP8266 2.2.0-dev(9422289)
MicroPython v1.11-8-g48dcbbe60 on 2019-05-29
flashbdev.size....: 1048576
reserved sectors..: 1
start sector......: 153
sector size.......: 4096
num blocks........: 106
0000 - 000f - eb fe 90 4d 53 44 4f 53 35 2e 30 00 10 01 01 00 - ..MSDOS5.0.....
0010 - 001f - f8 ff ff 00 f0 ff ff 0f 00 ff 0f 00 ff ff ff ff - ................
0020 - 002f - 42 4f 4f 54 20 20 20 20 50 59 20 20 18 00 51 b6 - BOOT....PY....Q.
0030 - 003f - e5 41 54 43 48 44 4f 47 4d 50 59 20 18 00 19 86 - .ATCHDOGMPY....
0040 - 004f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0050 - 005f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0060 - 006f - 4d 04 02 1f 20 82 00 03 00 30 00 00 00 07 07 00 - M.......0......
0070 - 007f - 4d 04 02 1f 20 84 28 08 00 00 00 00 00 07 07 00 - M....(.........
0080 - 008f - 4d 04 02 1f 20 81 04 02 00 30 00 00 00 07 07 00 - M.......0......
0090 - 009f - 4d 04 02 1f 20 81 14 02 00 30 00 00 00 07 07 00 - M.......0......
def detect_filesystem():
buf = bytearray(8)
flashbdev.bdev.readblocks(0, buf)
if buf[3:8] == b'MSDOS':
return 'FAT'
return 'unknown'
print(detect_filesystem())
EDIT2: Create a issue -> https://github.com/micropython/micropython/issues/5387os.VfsLfs.mkfs(flashbdev.bdev) # AttributeError: 'module' object has no attribute 'VfsLfs'
os.VfsLfs2.mkfs(flashbdev.bdev) # AttributeError: 'module' object has no attribute 'VfsLfs2'
I used the last stable build from: http://micropython.org/download#esp8266kevinkk525 wrote: ↑Fri Dec 06, 2019 3:15 pmMicroPython v1.11-8-g48dcbbe60 on 2019-05-29
You are using an old firmware build, pull the latest changes and build it again. littleFS will be included.
ESP module with ESP8266 2.0.0(5a875ba)
MicroPython v1.11-624-g210d05328 on 2019-12-06
start sector......: 213
0000 - 000f - 4d 04 02 1f 20 82 58 03 00 30 00 00 00 07 07 00 - M....X..0......
0010 - 001f - 4d 04 02 1f 20 84 64 04 00 30 00 00 00 07 07 00 - M....d..0......
0020 - 002f - 4d 04 02 1f 20 83 40 04 00 30 00 00 00 07 07 00 - M....@..0......
0030 - 003f - 4d 04 02 1f 20 81 4c 03 00 30 00 00 00 07 07 00 - M....L..0......
0040 - 004f - 4d 04 02 1f 20 84 2c 03 00 30 00 00 00 07 07 00 - M....,..0......
0010 - 001f - f8 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0020 - 002f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0030 - 003f - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - ................
0000 - 000f - 01 00 00 00 30 34 c0 39 12 0d f0 00 ee 07 2c 40 - ....04.9......,@
0010 - 001f - 39 12 3c f3 37 92 02 86 ad 00 5c b3 37 92 02 86 - 9.<.7..\.7.
0020 - 002f - 12 c1 10 0d f0 00 00 00 c6 31 2c 40 8a 31 2c 40 - .........1,@1,@
0030 - 003f - 7a e1 da f7 d8 0f e8 0e 00 46 40 30 f3 81 da ee - z........F@0...
0040 - 004f - c7 f8 30 30 f4 d8 51 88 81 98 91 c0 c0 f4 0c 04 - ..00..Q.....
Detected filesystem: unknown
convert to FAT...
Detected filesystem: FAT
convert to littlefs2...
File "<stdin>", line 58, in <module>
0010 - 001f - f8 ff ff ff 0f 00 00 00 00 00 00 00 00 00 00 00 - ................
0020 - 002f - 42 4f 4f 54 20 20 20 20 50 59 20 20 18 00 01 00 - BOOT....PY......
Is that right? I guess I'm out of luck.kevinkk525 wrote: ↑Fri Dec 06, 2019 4:22 pmyou can use the daily builds, it's basically what I use when building the firmware myself. They are stable.
xtensa-lx106-elf-ld: build-GENERIC/firmware.elf section `.irom0.text' will not fit in region `irom0_0_seg'
xtensa-lx106-elf-ld: region `irom0_0_seg' overflowed by 13344 bytes
irom0_0_seg : org = 0x40209000, len = 0xa7000
freeze('/mnt/qnap2/Scripts/modules/esp8266_modules')
freeze('$(MPY_DIR)/tools', ('upip.py', 'upip_utarfile.py'))
freeze('$(MPY_DIR)/drivers/dht', 'dht.py')
freeze('$(MPY_DIR)/drivers/onewire')
#! /bin/bash
cd /mnt/qnap2/data/Projects/MicroPython/micropython/ports/esp8266
MANIFEST='/mnt/qnap2/Scripts/manifests/esp8266_manifest.py'
if [ $# -eq 1 ] && [ $1 = "--clean" ]
then
make clean
fi
if [ $# -eq 1 ] && [ $1 = "--erase" ]
then
make clean
esptool.py --port /dev/ttyUSB0 erase_flash
fi
if make -j 8 FROZEN_MANIFEST=$MANIFEST MICROPY_VFS_LFS2=1
then
sleep 1
esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash --flash_size=detect -fm dio 0 build-GENERIC/firmware-combined.bin
cd -
sleep 4
rshell -p /dev/ttyUSB0 --editor nano --buffer-size=30
else
echo Build failure
fi
cd -
uos.VfsLfs2.mkfs(bdev)
vfs = uos.VfsLfs2(bdev)
# uos.VfsFat.mkfs(bdev)
# vfs = uos.VfsFat(bdev)
It all seems to me that it's not finished yet.
