Raising documentation issues
I see that the documentation has been updated over the holiday season and is much improved. Thanks guys!
However, I have noticed a few places where things are missing or more explanation would be useful.
Is there a single place where one can post suggestions for improvements to the documentation?
Re: Raising documentation issues
Have you considered creating pull requests to fix the doc issues? You can do that on github without having to download anything, only takes about 10 clicks...
+1 -- PR's are the best way to do this. Here's a very recent example from Peter: https://github.com/micropython/micropython/pull/5553
But, if you don't want to do that, it's still helpful to raise issues on github, so at least the suggested improvements are tracked.
Thanks guys, I will follow your advice and raise a PR. Thanks to jimmo for providing an example.
Guys, I followed your advice and failed miserably.
I signed in to Github, went to micropython/micropython, selected the Pull request tab and clicked the New pull request button. I then got a Compare Changes screen with the Create pull request button greyed out. What do I do now? I don't want to change any code so I've got nothing to compare against.
I looked again at Peter Hinch's PR. It's not really a good example. He references an issue with machine.RTC.rst so he has something to compare against.
The help documents don't seem to cover my scenario and I am going round in circles.
I appreciate that you all mean well, but tested and proven suggestions would be appreciated.
Create the pull request ist the latest step.
Easiest way is to browse to the source file and edit it on github. That will fork the repro and created a branch like "patch-1" and then you can create the pull request.
Thanks for your reply jedie, but it seems you haven't understood what I want to do.
I do not want to change any code. I just want to offer some suggestions for improving the documentation and was asking how best to do this.
If it's mere suggestions, open an issue on Github or post here on the forum.
Everything beyond that, i.e. you actually adding/improving documentation, does require changing files in the repository (whether it's considered 'code' or not is something else). And showing those changes to others/asking them for be to be merged into the main repository, means creating a PR. Are you sure that's not what you want to do?
Can you maybe just explain by example what you would actually want to do?
As stijn sayed, the documentation is a part of the source code repository, here: https://github.com/micropython/micropyt ... aster/docs
e.g.: The page "The MicroPython Interactive Interpreter Mode (aka REPL)" http://docs.micropython.org/en/latest/r ... /repl.html will be generated from this file: https://github.com/micropython/micropyt ... e/repl.rst
If you want to change something on this page, edit this file and create a pull request. Start point is here:
Help about the workflow on github is here: https://help.github.com/en/github/manag ... repository
