this is the code i am currently using.
from time import sleep
from dht import DHT22
SERVER = '192.168.1.22' # MQTT Server Address (Change to the IP address of your Pi)
CLIENT_ID = 'ESP32_DHT22_Sensor'
TOPIC = b'temp_humidity'
client = MQTTClient(CLIENT_ID, SERVER)
client.connect() # Connect to MQTT broker
sensor = DHT22(Pin(15, Pin.IN, Pin.PULL_UP)) # DHT-22 on GPIO 15 (input with internal pull-up resistor)
sensor.measure() # Poll sensor
t = sensor.temperature()
h = sensor.humidity()
if isinstance(t, float) and isinstance(h, float): # Confirm sensor results are numeric
msg = (b'{0:3.1f},{1:3.1f}'.format(t, h))
client.publish(TOPIC, msg) # Publish sensor data to MQTT topic
print(msg)
print('Invalid sensor readings.')
except OSError:
print('Failed to read sensor.')
sleep(4)
I'm not getting errors, but when ever I restart the ESP32. It doesn’t connect back the Mqtt , I have to go back to REPL and import the code that we submit to work so all I want it to do is to connect to the Mqtt by it self.
