Purchased a Pyboard D SF2. Brand new to python and micro-controllers.
Plugged it in to Win 10 machine
Was trying to turn some LEDs to start out
ran boot.pu file that had, import machine and import pyb
it returned...no module named 'machine'
Any ideas. I probably seem like an idiot to you guys. However this looks fun
How do i start
Re: How do i start
The pyboard d (like most MicroPython boards) has an internal filesystem that stores Python code that the board will execute.
When you plug it into your computer, shows up as a USB flash drive which shows the contents of the filesystem.
It sounds like you're trying to run the code on your PC (i.e. by double-clicking the file). Instead what you need to do is write your code, then save it to the device, then reset it (ideally via a serial console so you can see any messages).
Have you seen the "getting started" guide - http://docs.micropython.org/en/latest/p ... index.html -- in particular this page is probably what you need: http://docs.micropython.org/en/latest/p ... cript.html The next page has instructions on how to set up PuTTY so you can access the serial console.
Re: How do i start
Thanks, very helpful. Used Putty and was able to toggle the LEDs on and off. My 6 year old thought it was awesome and says we should build a terminator.
