I´m really new with micropython and I was trying to work with the LIS3DH sensor throught SPI but i cannt get it to work.
This is the code that I was running:
MicroPython v1.11-576-gd667bc642 on 2019-11-13; PYBD-SF6W with STM32F767IIK
>>> from machine import SPI, Pin
>>> import lis3dh
>>> Pin('EN_3V3').value(1)
>>> spi=SPI(1)
>>> spi.init(baudrate=100000, polarity=0, phase=0)
>>> b=lis3dh.LIS3DH_SPI(spi)
TypeError: function missing required positional argument #3
I was trying to define the CS pin too ,
>>> cs = machine.Pin('X5')
>>> b=lis3dh.LIS3DH_SPI(spi, cs)
File "/flash/lib/lis3dh.py", line 363, in __init__
ImportError: no module named 'adafruit_bus_device'
I´ve downloaded the driver here:
https://github.com/adafruit/Adafruit_Ci ... hon_LIS3DH
Could you please help me with this?
Thanks so much in advance!!
LIS3DH sensor with SPI
Re: LIS3DH sensor with SPI
This is a CircuitPython library, so it will not work on standard MicroPython. (CircuitPython shares the same core language and VM but has a completely different set of APIs for writing drivers).
It's usually not too difficult to rewrite a CircuitPython driver into MicroPython once you're familiar with both APIs. (replace digitalio with machine.Pin and adafruit_bus_device.spi_device with machine.SPI).
Maybe as a starting point here's another driver (writen for a SPI (or I2C) OLED display) that shows what a typical SPI MicroPython driver might look like. https://github.com/micropython/micropyt ... ssd1306.py
If you want to have a go at it feel free to ask questions here... converting drivers to MicroPython is a topic that's discussed reasonably often.
I will try to rewrite the library as you indicated....thanks so much for your help!!!
sorry, I was trying to convert the code but im getting always the error "AttributeError: 'module' object has no attribute 'LIS3DH_SPI'"
>>> cs = machine.Pin('X5', machine.Pin.OUT)
>>> spi=SPI(1)
>>> import lis3dh
>>> sensor=lis3dh.LIS3DH_SPI(spi, cs)
attached you can find the driver.
I will appreciate any input you could give me. Thanks so much in advance!!
>>> spi=SPI(1)
>>> import lis3dh
- lis3dh.rar
- (4.06 KiB) Downloaded 450 times
I don't think you've updated the file on the device correctly -- the file you posted there doesn't compile (due to indent errors), so the import would have failed.
It's likely that it's still loading the old version.
If you're using a pyboard, then either pyboard.py or rshell are the best ways to work with files on the device. http://docs.micropython.org/en/latest/r ... rd.py.html
If you're using the flash drive interface, then copy the files, then make sure to wait for the red led to turn off and then soft-reset from the REPL using Ctrl-D. (But I strongly recommend using pyboard.py or rshell instead).
you were right i was having also problems with that. Thanks so much for your help.
I could import correctly the library (and also the I2C is working without any issue)
but I cannt get it to work with the SPI interface.
>>> import lis3dh
>>> spi=SPI(1)
File "/flash/lib/lis3dh.py", line 314, in __init__
File "/flash/lib/lis3dh.py", line 65, in __init__
File "/flash/lib/lis3dh.py", line 271, in _read_register_byte
File "/flash/lib/lis3dh.py", line 321, in _read_register
AttributeError: 'SPI' object has no attribute '__exit__'
I think i´m not configuring the SPI correctly in the library. Could you please help me with that?
thanks so much!!!!
>>> import lis3dh
>>> spi=SPI(1)
thanks so much!!!!
- lis3dh.rar
- (4.01 KiB) Downloaded 671 times
The issue is
MicroPython's SPI object doesn't support enter/exit (i.e. the "with" statement / context manager). I don't know CircuitPython very well but my guess is that they use this to toggle the CS pin (their SPI object knows about the CS pin). So just remove the "with self._spi" part and use self._spi directly, and set self._cs low at the beginning of the function and high at the end.
with self._spi as spi:
spi.write(self._buffer, start=0, end=1) # pylint: disable=no-member
spi.readinto(self._buffer, start=0, end=length) # pylint: disable=no-member
return self._buffer
Thanks so much for you help.
sorry for bothering you again, but I was trying to implement it as you indicated me but i´m still getting errors.
>>> import lis3dh
>>> spi=SPI(1)
TypeError: 'NoneType' object isn't subscriptable
I will apreciate any input, thanks so much for your time!!
>>> import lis3dh
>>> spi=SPI(1)
- lis3dh.rar
- (4.02 KiB) Downloaded 503 times
__init__ calls read_register_byte, which calls "self._read_register(register, 1)[0]", which is implemented in LIS3DH_SPI
In the case where length == 1, it doesn't return anything (i.e. it returns None), hence the error "'NoneType' object isn't subscriptable" when read_register_byte tries to access the [0]'th element.
