rshell - Remote Shell
yogotech
Re: rshell - Remote Shell
Post by yogotech » Thu Mar 05, 2020 6:05 am
jimmo wrote:
Thu Mar 05, 2020 5:22 am
yogotech wrote:
Thu Mar 05, 2020 4:51 am
How can I do this with rshell, and is there a way to capture the output?
I think the idea is that you use the "repl" command to get to the MicroPtyhon prompt hit Ctrl-D to soft reset (if you've previously loaded this file), then run "import blink"
rshell> repl ~ import blink~
to enter the repl and run the command and then back to rshell.
/pyboard> repl ~ import blink ~
Entering REPL. Use Control-X to exit.
MicroPython v1.12 on 2019-12-20; ESP32 module with ESP32
>>> import blink
ImportError: no module named 'blink'
>>> /pyboard>
No joy. The above may be due to my unfamiliarity with python, as my simple example code is not a class per-se, but it should be easy to just 'run' the file similar to how ampy does.
wr300000
Post by wr300000 » Thu Mar 05, 2020 6:39 am
Normally I use screen to enter REPL. I recently use rshell as IDE
rshell -p /dev/ttyUSB0 --editor nano --buffer-size=30
/home/wr300000> repl <---- get in repl and release machine.reset() to rerun my main.py
Below is result from my main.py showing normal /sd directory and other configured variables.
GC:
37952 total
12256 : 25696
1=84 2=8 m=264
free RAM = 9312 bytes
I2C(PCF8574) LCD not found
free SDcard = 7926009856 bytes
total SDcard = 7931396096 bytes
stack: 2768 out of 8192
GC: total: 37952, used: 12880, free: 25072
No. of 1-blocks: 99, 2-blocks: 8, max blk sz: 264, max free sz: 1457
Thr 5 MAR 2020 - 12:39 UTC+ 7
MicroPython v1.12-195-gb16990425-dirty on 2020-03-03; ESP module with ESP8266
>>> dir()
['winteroff', 'uos', 'sdcheck', 'nettime', 'ppwmstop', 'mem_info', 'clear', 'os', 'sd', 'gc', 'dayl', 'pwordd', 'plow', 'pscl', 'sid', 'esp', 'cat', 'cp', 'platform', 'sdcard', 'pword', 'sleep_ms', 'dlboot', 'machine', 'Pin', 'ssidd', 'sync_ntp', 'i2cPinSCL', 'summeroff', 'I2C', 'now', 'soff', 'webrepl', 'ticks_ms', 'phigh', 'i2cPinSDA', 'bdev', '__name__', 'ppwm', 'delayboot', 'psda', 'daylight', 'woff'] <---- /sd and configured variable are present
>>> os.listdir()
['sd', 'boot.py', 'main.py', 'webrepl_cfg.py', 'confighw.py', 'conf.py', 'board.py'] <---- before ctrl-X
>>> <---- ctrl-X to shell
/home/wr300000> ls /pyboard <---- release rshell list command
board.py conf.py main.py
boot.py confighw.py webrepl_cfg.py <---- /sd and all configured variable gone
>>> dir() <---- /sd and all configured variable gone
['bdev', 'get_stat', '__name__', 'stat', 'uos', 'esp', 'webrepl', 'gc', 'output']
Why did rshell Iist command effect to main.py ?
Post by jimmo » Thu Mar 05, 2020 7:30 am
You also need to cp blink.py to the device.
Post by pythoncoder » Thu Mar 05, 2020 9:04 am
The way I work is as follows. I use a programmers' editor (Kate) to edit a file, say myfile.py. Assume I want to run myfile.main(). From the directory containing the file I run rshell. Let's say the target is a Pyboard with an SD card. At the rshell prompt I issue
path> cp myfile.py /sd
repl
>>> import myfile
>>> myfile.main()
ctrl-x takes you back to rshell.
Note this can be streamlined, so after ctrl-x all you need is an uparrow to run an edited version:
path> cp myfile.py /sd; repl ~ import myfile ~ myfile.main()
yogotech
Post by yogotech » Fri Mar 06, 2020 12:04 am
ARGH, it was on the device, but I must have fat-fingered it.
:evil:
Thanks (I feel stupid now).
yogotech
Post by yogotech » Fri Mar 06, 2020 12:06 am
repl
>>> import myfile
>>> myfile.main()
This would work for me, but many of the example programs I'm using haven't defined a main method, so it appears that just
>>> import myfile
Is probably adequate for them.
[ I still think having a run command would be faster and more intuitive, but I'll quit whining now.... ;) ]
Thanks everyone!
Post by pythoncoder » Fri Mar 06, 2020 6:52 am
I'm not sure what you're advocating but you could look at pyboard.py to see if that fits the bill.
An rshell line like the one I posted (which is easily adapted for your case with no main() function) gives an extremely fast edit-test cycle because of rshell's ability to recall previous lines.
SpotlightKid
Post by SpotlightKid » Mon May 11, 2020 6:14 pm
Would it be possible to tag new releases of rhell in the repo and also mark them as releases on https://github.com/dhylands/rshell/releases (in addition to the releases on PyPI)?
This would make it easier for distribution package maintainers to get notified about new releases (I recently took over maintenance of the rshell AUR package).
Post by dhylands » Mon May 11, 2020 6:35 pm
Yeah - I could do that.
I added releases for 0.0.27 and 0.0.28
SpotlightKid
Post by SpotlightKid » Mon May 11, 2020 7:08 pm
Very nice.Thank you.
