I tried to make this module as simple as possible to try and understand how to use mp_hal_delay_ms() in a native module. It's just a wrapper called mydelay.
So I have these two files (based on the factorial example). mydelay.c and Makefile as follows:
// Include the header file to get access to the MicroPython API
//#include "py/mphal.h"
#include "py/dynruntime.h"
// This is the function which will be called from Python, as delay_ms(x)
STATIC mp_obj_t delay_ms(mp_obj_t x_obj) {
// Extract the integer from the MicroPython input object
mp_int_t x = mp_obj_get_int(x_obj);
mp_printf(&mp_plat_print,"delaying for " INT_FMT " ms...\n",x);
//mp_hal_delay_ms(x);
return mp_const_none;
STATIC mp_obj_t delay_us(mp_obj_t x_obj) {
mp_printf(&mp_plat_print,"delaying for " INT_FMT " us...\n",x);
//mp_hal_delay_us(x);
// Define a Python reference to the function above
STATIC MP_DEFINE_CONST_FUN_OBJ_1(delay_ms_obj, delay_ms);
STATIC MP_DEFINE_CONST_FUN_OBJ_1(delay_us_obj, delay_us);
// This is the entry point and is called when the module is imported
mp_obj_t mpy_init(mp_obj_fun_bc_t *self, size_t n_args, size_t n_kw, mp_obj_t *args) {
// This must be first, it sets up the globals dict and other things
MP_DYNRUNTIME_INIT_ENTRY
// Make the function available in the module's namespace
mp_store_global(MP_QSTR_delay_ms, MP_OBJ_FROM_PTR(&delay_ms_obj));
mp_store_global(MP_QSTR_delay_us, MP_OBJ_FROM_PTR(&delay_us_obj));
// This must be last, it restores the globals dict
MP_DYNRUNTIME_INIT_EXIT
# Location of top-level MicroPython directory
MPY_DIR = ../..
# Name of module
MOD = mydelay
# Source files (.c or .py)
SRC = mydelay.c
# Architecture to build for (x86, x64, armv7m, xtensa, xtensawin)
ARCH = armv7m
# Include to get the rules for compiling and linking the module
include $(MPY_DIR)/py/dynruntime.mk
lj@mint:~/projects/micropython-1.12/examples/mydelay$ make
GEN build/mydelay.config.h
CC mydelay.c
LINK build/mydelay.o
arch: EM_ARM
text size: 248
bss size: 0
GOT entries: 2
GEN mydelay.mpy
MicroPython v1.12 on 2020-05-30; MCUDEV STM32F407VE with STM32F407VE
>>> import mydelay
>>> mydelay.delay_ms(150)
delaying for 150 ms...
>>> mydelay.delay_us(200)
delaying for 200 us...
CC mydelay.c
In file included from mydelay.c:2:0:
../../py/mphal.h:34:10: fatal error: mphalport.h: No such file or directory
#include <mphalport.h>
compilation terminated.
../../py/dynruntime.mk:128: recipe for target 'build/mydelay.o' failed
make: *** [build/mydelay.o] Error 1
Cheers,
John
