uasyncio - How detect the end task in another task.
Primesty
Re: uasyncio - How detect the end task in another task.
Post by Primesty » Tue Jul 28, 2020 2:07 pm
Will do and re-write according to the tutorial!
Primesty
Post by Primesty » Fri Jul 31, 2020 7:51 pm
Hi Peter!
I was able to re-write the code according to your tutorial so that it's not legacy anymore:
from machine import Pin, Timer, I2C
import dht
import uasyncio
import gc
from my_app import temp_reader
led = Pin(2, Pin.OUT)
def set_global_exception():
    def handle_exception(loop, context):
        import sys
        sys.print_exception(context["exception"])
        sys.exit()
    loop = uasyncio.get_event_loop()
    loop.set_exception_handler(handle_exception)
async def main():
    set_global_exception()  # Debug aid
    my_class = temp_reader(led)  # Constructor might create tasks
    uasyncio.create_task(my_class.blink())  # Or you might do this
    await my_class.cancel()  # Non-terminating method
    uasyncio.run(main())
finally:
    uasyncio.new_event_loop()  # Clear retained state
main()
gc.collect()
gc.threshold(gc.mem_free() // 4 + gc.mem_alloc())
The led-blink example still works and the class with the blink method and the cancel method is in a file *my_app.py* .
Should I now first implement a temp_reader method or work on the encoder method? I assume both will then have to be put into **uasyncio.create_task()** above. Should the temperature measurement OR the encoder be non-terminating methods - for the last line above, e.g.
await my_class.temp_measure() # Non-terminating method
? Please let me know what you think. Happy weekend!
Post by pythoncoder » Sat Aug 01, 2020 7:30 am
A typical firmware application will have several non-terminating tasks. Your main() task starts all but one by issuing .create_task() and then awaits the last task: this ensures that the scheduler itself runs forever.
In many cases it doesn't matter which task you await - it's only an issue if the application logic requires the tasks to be started in a defined order.
Primesty
Post by Primesty » Sat Aug 01, 2020 3:04 pm
Gotcha! Thanks for the input - once I have my drivers up and running again - I'll continue building the coros.
Primesty
Post by Primesty » Fri Aug 07, 2020 8:16 pm
Hi Pete,
I got my system up and running again :)
I've successfully implemented code that blinks the led *and* reads the temperature at the same time according to your specs and tutorial.
One question popped up.
When I run this:
import dht
import uasyncio
import gc
sensor = dht.DHT22(Pin(14))
class tempReader():
  sleep = 1 #static instance variable for testing
  def __init__(self, led, sensor):
    self.led = led
    self.sensor = sensor
  async def blink(self):
        self.led.on()
        await uasyncio.sleep(tempReader.sleep)
        self.led.off()
  async def temp(self):
      self.sensor.measure()
      temp = self.sensor.temperature()
      print('Temperature: %3.1f C' %temp)
      await uasyncio.sleep(2)
  async def cancel(self):
    await uasyncio.sleep(10) #stops the loop after 10 seconds
        import sys
        sys.exit()
async def main():
    my_class = tempReader(led, sensor)  # Constructor might create tasks
    uasyncio.create_task(my_class.temp())
finally:
main()
gc.collect()
It works without a hitch. However, when I have the class in another file, like so
main.py
import dht
import uasyncio
import gc
from my_app import tempReader
        import sys
        sys.exit()
async def main():
finally:
main()
gc.collect()
my_app.py
import dht
import uasyncio
import gc
class tempReader():
    self.led = led
        self.led.on()
        self.led.off()
I get this error
TypeError: function takes 2 positional arguments but 3 were given
It seems that the second class method is not imported correctly to main.py. I'm under the impression that the sensor object has to go into the class instantiation process, right?
Do you know what might be causing this?
Have a great weekend!
Matthias
Post by pythoncoder » Sat Aug 08, 2020 12:34 pm
I can't spot the cause. It would help if you told us the line number where the error occurs.
It's worth noting that the following code will only be executed after you interrupt the program or after it fails with an exception:
main()
gc.collect()
This is because execution passes to the scheduler with
Primesty
Post by Primesty » Sat Aug 08, 2020 12:54 pm
Gotcha, I removed the dangling main() function call
Also, the above error has resolved itself and now it's running smoothly, which means I can now move on to handling the rotary encoder or displaying the temperature.
Primesty
Post by Primesty » Sat Aug 15, 2020 4:52 pm
Hey Pete,
I tried installing a daily build on an ESP8266 today to get the latest version of uasyncio on there, but that led to urequests not being available anymore, which only seems to be available in stable versions. Are you aware of any ESP8266 builds, which have all standard libraries including urequests AND the latest version of uasyncio?
Thanks!
Post by pythoncoder » Sun Aug 16, 2020 3:25 pm
You'll need to install it with upip. I'm not familiar with urequests so I suggest you read this to figure out which version you need.
Primesty
Post by Primesty » Fri Aug 21, 2020 6:30 pm
Hey Pete,
Thanks for the ESP8266 tip. I've been working some more on my temp-reader project and am testing your aswitch.py functions to be able to give the app potentially more functionality.
I've also written a class method, which now shows the current temperature reliably on the OLED. Then, I went into button testing with three external LEDs.
import dht
import uasyncio
import gc
import ssd1306
from aswitch import Switch, Pushbutton
led2 = Pin(19, Pin.OUT)
led3 = Pin(32, Pin.OUT)
led4 = Pin(33, Pin.OUT)
sw = Pin(18, Pin.IN, Pin.PULL_UP)
i2c = I2C(-1, scl=Pin(22), sda=Pin(21))
oled_width = 128
oled_height = 64
oled = ssd1306.SSD1306_I2C(oled_width, oled_height, i2c)
async def pulse(led, ms):
    for i in range(5):
      led.on()
      await uasyncio.sleep_ms(ms)
      led.off()
async def blink2(led):
    for i in range(5):
      led.on()
      await uasyncio.sleep_ms(100)
      led.off()
async def blink3(led):
    for i in range(10):
      led.on()
      await uasyncio.sleep_ms(200)
      led.off()
async def nothing():
  await uasyncio.sleep_ms(2)
        import sys
        sys.exit()
async def main():
    my_class = tempReader(led, sensor, oled)  # Constructor might create tasks
    switch = Pushbutton(sw, suppress = True)
    switch.press_func(pulse, (led3, 1000))
    switch.release_func(nothing, ()) #check to see if there is a long or double func
    switch.double_func(blink2, (led2,))
    switch.long_func(blink3, (led4,))
    uasyncio.create_task(my_class.show())
finally:
gc.collect()
All button functions work, the double click and long click trigger the right functions. However, even though I have set suppress = True in the Pushbutton class and have a release function. The press_func still runs and runs the pulse function. I'm sure I'm missing something that prevents that from really suppressing it. Do you see why that might be happening?
