nrf52840 DK PCA10056 (could not enter raw REPL)
M.Ridwan
Post by M.Ridwan » Tue Aug 25, 2020 12:53 pm
Dear Colleagues,
I want to copy the Python Script in nrf52840 DK PCA10056 by using Zephyr Port and I am using the method as given in the link http://docs.micropython.org/en/v1.12/re ... rd.py.html and I am getting the following error:
python3 pyboard.py --device /dev/ttyACM0 light.py
b'>>> \r\n>'
could not enter raw repl
Please Advise.
federico
Re: nrf52840 DK PCA10056 (could not enter raw REPL)
Post by federico » Sun Aug 30, 2020 10:28 am
I don't know if the following trial will solve your problem, anyway give it an chance.
I suggest the following trial involving the substitution of your pyboard.py ( after a safety backup of the same)
Why ?
Please, read from:
https://bigl.es/microcontroller-monday-wemos-w600-pico/
pyboard.py - this version can be download from:
https://drive.google.com/file/d/1qCvD3Z ... sp=sharing
"I got an error stating that ampy could not enter a raw repl and this caused the application to exit
And then copied the new pyboard.py file from my Downloads directory to the ampy directory.
" etc..
federico
Post by federico » Tue Sep 01, 2020 1:43 am
This is the involved method :
def enter_raw_repl(self)
where the changes are commented
federico
Post by federico » Tue Sep 01, 2020 9:00 pm
From the attachment 1,2,3,4,5 we have a practical demonstration about the results of interaction with an W600-PICO board, by an unchanged pyboard.py and an changed one.
The traceback says that the problem arise from the enter_raw_repl method defined in the class Pyboard ( line 192 of pyboard.py).
get
changed pyboard.py
pyboard enter_raw_repl changes
result with unchanged pyboard.py
federico
Post by federico » Wed Sep 02, 2020 1:23 am
We have from the following address the correct syntax to copy a file to the board:
https://docs.micropython.org/en/latest/ ... rd.py.html
The cp command uses a ssh-like convention for referring to local and remote files. Any path starting with a : will be interpreted as on the device, otherwise it will be local. So:
$ pyboard.py --device /dev/ttyACM0 -f cp main.py :main.py
will copy main.py from the current directory on the PC to a file named main.py on the device. The filename can be omitted, e.g.:
is equivalent to the above.
Your is :
federico
Post by federico » Wed Sep 02, 2020 7:56 pm
I have upgraded my pyboard.py version with the last one on github ( doesn't require the ampy support) - I newly have changed the enter_raw_repl() in the Pyboard class and simulated your requirement as from the attachment - without any problem -
pyboard.py last version
