I2C TypeError:extra positional arguments given
fmentiplay
Post by fmentiplay » Thu Oct 29, 2020 11:56 am
This code works ...
>>>From machine import I2C, Pin
>>>i2c = I2C(scl=Pin(22), sda=Pin(21))
This code has error ...
>>>scl = Pin(22)
>>>sda = Pin(21)
>>>i2c = I2C(scl, sda)
File "<stdin", line 1, in <module>
TypeError: extra positional arguments given
Why doesn't this work!! What is differnt about the two blocks of code?
Any help much apreciated
Frank
Re: I2C TypeError:extra positional arguments given
Post by jimmo » Thu Oct 29, 2020 12:24 pm
The I2C class must take the "scl" and "sda" arguments as keyword arguments. This is common in a few places in MicroPython (and other Python libraries) for optional arguments, as it makes it easier to read the code that uses it (there's no guessing which one of the optional arguments it is).
To make the second example work, use scl=scl and sda=sda.
>>>scl = Pin(22)
>>>sda = Pin(21)
>>>i2c = I2C(scl=scl, sda=sda)
The equivalent in Python is:
>>> def foo(x, *, y=0, z=0):
...   print(x, y, z)
>>> foo(1)
1 0 0
>>> foo(1, 2, 3)
TypeError: foo() takes 1 positional argument but 3 were given
>>> foo(1, y=2, z=3)
1 2 3
fmentiplay
Post by fmentiplay » Thu Oct 29, 2020 11:12 pm
Thank You for your very clear answer. Very much appreciated
