webbhm wrote: ↑Tue Nov 17, 2020 8:18 pm
I am having a similar issue with a PYBD-SF2W where the SD card is present but will not mount. The boot file errors out, then the /flash/main.py gets called.
I have tried several SD cards, did a factory reset as well as a re-flashing of the firmware - all with no change. I am concerned this might be a hardware issue (ie: failure on block read)(SD card holder?).
This is a data logger project, and the board had successfully run for several days logging over 500K records to the SD, in a standby/log cycle at 2 second intervals. For the last day I had slowed it down to 1 cycle/minute. I was changing files on the SD card when this started to occur. Is this problem expected after this much activity, or are there any suggestions?
Note: line 12 of boot.py is:
os.mount(pyb.SDCard(), '/sd')
The following is from running REPL:
File "boot.py", line 12, in <module>
OSError: 16
Connected at: 192.168.1.186
MicroPython v1.13 on 2020-09-02; PYBD-SF2W with STM32F722IEK
>>> import pyb, os
>>> pyb.SDCard().present()
True
OSError: 16
>>> print(pyb.SDCard().read(0))
Exception: sdcard_read_blocks failed [1]
Thanks,
HW
