I have a BLE device that controls a string of coloured LEDs. I can control this with the app and I can find it using the BLE scanner on my phone:
Luckily someone has decoded the commands and I was also able to send a command via a byte array from the scanner to change the colour.
I want to try and send command from with micropython on an esp32 however I cannot get the BLE scan function to find it, or anything else. I have used the ble_simple_central.py from the examples/bluetooth folder. But it comes back saying nothing found. Tried a number of esp32 boards but the same result in all of them.
I switched one of them to arduino and flashed with the BLE scan program and get the following output
Advertised Device: Name: ELK-BLEDOM , Address: be:89:a0:00:b0:4e
Advertised Device: Name: , Address: 7d:2e:0e:f5:a7:59, manufacturer data: e00000f2ca6ddba0, serviceUUID: 0000fe9f-0000-1000-8000-00805f9b34fb
Advertised Device: Name: , Address: 7c:5b:88:e2:ee:af, manufacturer data: e00000c8ca900a60, serviceUUID: 0000fe9f-0000-1000-8000-00805f9b34fb
Advertised Device: Name: , Address: 64:74:57:c3:3f:e1, serviceUUID: 0000fd6f-0000-1000-8000-00805f9b34fb
Advertised Device: Name: , Address: 72:a0:1e:5e:b4:39, manufacturer data: e0000081ca692e38, serviceUUID: 0000fe9f-0000-1000-8000-00805f9b34fb
Is there something obvious I am missing about why I can't get this to appear in micropython? My first attempt at doing anything with BLE so quite possible.
Thanks.
Should also say tried a number of different stock firmwares. 1.12, 1.13 & 1.13 latest unstable idf v3 and 1.13 idf v4.
