AAMOI when you wrote your driver did you manage to track down a programming manual?
def change_id(self, new_id):
self.writeReg(0x0001, new_id & 0x7F)
pyb.delay(50)
self.address = new_id
JonHylands wrote: ↑Fri Nov 27, 2020 9:59 pmSo I'm working on Roz, my bioloid quad walker, and I've built a new head with five VL53L1X sensors in it.
It turns out the OpenMV project has a perfectly functional VL53L1X library:
https://github.com/openmv/openmv/blob/m ... vl53l1x.py
That works for a single sensor. I added a new method to allow the user to change the id of the current sensor:
You need a lot of pauses in the right places to initialize 5 of the sensors, but it works, and I have it running.Code: Select all
def change_id(self, new_id): self.writeReg(0x0001, new_id & 0x7F) pyb.delay(50) self.address = new_id
from machine import I2C
self.i2c = I2C(HEAD_I2C_BUS)
HEAD_SHUTDOWN_LEFT = pyb.Pin.cpu.C3
HEAD_SHUTDOWN_FRONT_LEFT = pyb.Pin.cpu.B9
HEAD_SHUTDOWN_FRONT = pyb.Pin.cpu.B8
HEAD_SHUTDOWN_FRONT_RIGHT = pyb.Pin.cpu.C6
HEAD_SHUTDOWN_RIGHT = pyb.Pin.cpu.C7
HEAD_RANGE_DEFAULT_ADDRESS = 0x29
HEAD_RANGE_FRONT_ADDRESS = 0x30
HEAD_RANGE_FRONT_LEFT_ADDRESS = 0x31
HEAD_RANGE_FRONT_RIGHT_ADDRESS = 0x32
HEAD_RANGE_LEFT_ADDRESS = 0x33
HEAD_RANGE_RIGHT_ADDRESS = 0x34
def initializeRangeSensors(self):
shutdown_left_pin = pyb.Pin(HEAD_SHUTDOWN_LEFT, pyb.Pin.OUT_PP)
shutdown_front_left_pin = pyb.Pin(HEAD_SHUTDOWN_FRONT_LEFT, pyb.Pin.OUT_PP)
shutdown_front_pin = pyb.Pin(HEAD_SHUTDOWN_FRONT, pyb.Pin.OUT_PP)
shutdown_front_right_pin = pyb.Pin(HEAD_SHUTDOWN_FRONT_RIGHT, pyb.Pin.OUT_PP)
shutdown_right_pin = pyb.Pin(HEAD_SHUTDOWN_RIGHT, pyb.Pin.OUT_PP)
# Shut down all the sensors
shutdown_left_pin.value(0)
shutdown_front_left_pin.value(0)
shutdown_front_right_pin.value(0)
shutdown_right_pin.value(0)
shutdown_front_pin.value(0)
pyb.delay(250)
shutdown_front_pin.value(1)
pyb.delay(250)
self.front_lidar = VL53L1X(self.i2c, address=HEAD_RANGE_DEFAULT_ADDRESS)
pyb.delay(100)
self.front_lidar.change_id(HEAD_RANGE_FRONT_ADDRESS)
pyb.delay(100)
shutdown_front_left_pin.value(1)
pyb.delay(100)
self.front_left_lidar = VL53L1X(self.i2c, address=HEAD_RANGE_DEFAULT_ADDRESS)
pyb.delay(100)
self.front_left_lidar.change_id(HEAD_RANGE_FRONT_LEFT_ADDRESS)
pyb.delay(100)
shutdown_front_right_pin.value(1)
pyb.delay(100)
self.front_right_lidar = VL53L1X(self.i2c, address=HEAD_RANGE_DEFAULT_ADDRESS)
pyb.delay(100)
self.front_right_lidar.change_id(HEAD_RANGE_FRONT_RIGHT_ADDRESS)
pyb.delay(100)
shutdown_left_pin.value(1)
pyb.delay(100)
self.left_lidar = VL53L1X(self.i2c, address=HEAD_RANGE_DEFAULT_ADDRESS)
pyb.delay(100)
self.left_lidar.change_id(HEAD_RANGE_LEFT_ADDRESS)
pyb.delay(100)
shutdown_right_pin.value(1)
pyb.delay(100)
self.right_lidar = VL53L1X(self.i2c, address=HEAD_RANGE_DEFAULT_ADDRESS)
pyb.delay(100)
self.right_lidar.change_id(HEAD_RANGE_RIGHT_ADDRESS)
pyb.delay(100)
import rp2
import utime
VL51L1X_DEFAULT_CONFIGURATION = bytes([
0x00, # 0x2d : set bit 2 and 5 to 1 for fast plus mode (1MHz I2C), else don't touch */
0x00, # 0x2e : bit 0 if I2C pulled up at 1.8V, else set bit 0 to 1 (pull up at AVDD) */
0x00, # 0x2f : bit 0 if GPIO pulled up at 1.8V, else set bit 0 to 1 (pull up at AVDD) */
0x01, # 0x30 : set bit 4 to 0 for active high interrupt and 1 for active low (bits 3:0 must be 0x1), use SetInterruptPolarity() */
0x02, # 0x31 : bit 1 = interrupt depending on the polarity, use CheckForDataReady() */
0x00, # 0x32 : not user-modifiable */
0x02, # 0x33 : not user-modifiable */
0x08, # 0x34 : not user-modifiable */
0x00, # 0x35 : not user-modifiable */
0x08, # 0x36 : not user-modifiable */
0x10, # 0x37 : not user-modifiable */
0x01, # 0x38 : not user-modifiable */
0x01, # 0x39 : not user-modifiable */
0x00, # 0x3a : not user-modifiable */
0x00, # 0x3b : not user-modifiable */
0x00, # 0x3c : not user-modifiable */
0x00, # 0x3d : not user-modifiable */
0xff, # 0x3e : not user-modifiable */
0x00, # 0x3f : not user-modifiable */
0x0F, # 0x40 : not user-modifiable */
0x00, # 0x41 : not user-modifiable */
0x00, # 0x42 : not user-modifiable */
0x00, # 0x43 : not user-modifiable */
0x00, # 0x44 : not user-modifiable */
0x00, # 0x45 : not user-modifiable */
0x20, # 0x46 : interrupt configuration 0->level low detection, 1-> level high, 2-> Out of window, 3->In window, 0x20-> New sample ready , TBC */
0x0b, # 0x47 : not user-modifiable */
0x00, # 0x48 : not user-modifiable */
0x00, # 0x49 : not user-modifiable */
0x02, # 0x4a : not user-modifiable */
0x0a, # 0x4b : not user-modifiable */
0x21, # 0x4c : not user-modifiable */
0x00, # 0x4d : not user-modifiable */
0x00, # 0x4e : not user-modifiable */
0x05, # 0x4f : not user-modifiable */
0x00, # 0x50 : not user-modifiable */
0x00, # 0x51 : not user-modifiable */
0x00, # 0x52 : not user-modifiable */
0x00, # 0x53 : not user-modifiable */
0xc8, # 0x54 : not user-modifiable */
0x00, # 0x55 : not user-modifiable */
0x00, # 0x56 : not user-modifiable */
0x38, # 0x57 : not user-modifiable */
0xff, # 0x58 : not user-modifiable */
0x01, # 0x59 : not user-modifiable */
0x00, # 0x5a : not user-modifiable */
0x08, # 0x5b : not user-modifiable */
0x00, # 0x5c : not user-modifiable */
0x00, # 0x5d : not user-modifiable */
0x01, # 0x5e : not user-modifiable */
0xdb, # 0x5f : not user-modifiable */
0x0f, # 0x60 : not user-modifiable */
0x01, # 0x61 : not user-modifiable */
0xf1, # 0x62 : not user-modifiable */
0x0d, # 0x63 : not user-modifiable */
0x01, # 0x64 : Sigma threshold MSB (mm in 14.2 format for MSB+LSB), use SetSigmaThreshold(), default value 90 mm */
0x68, # 0x65 : Sigma threshold LSB */
0x00, # 0x66 : Min count Rate MSB (MCPS in 9.7 format for MSB+LSB), use SetSignalThreshold() */
0x80, # 0x67 : Min count Rate LSB */
0x08, # 0x68 : not user-modifiable */
0xb8, # 0x69 : not user-modifiable */
0x00, # 0x6a : not user-modifiable */
0x00, # 0x6b : not user-modifiable */
0x00, # 0x6c : Intermeasurement period MSB, 32 bits register, use SetIntermeasurementInMs() */
0x00, # 0x6d : Intermeasurement period */
0x0f, # 0x6e : Intermeasurement period */
0x89, # 0x6f : Intermeasurement period LSB */
0x00, # 0x70 : not user-modifiable */
0x00, # 0x71 : not user-modifiable */
0x00, # 0x72 : distance threshold high MSB (in mm, MSB+LSB), use SetD:tanceThreshold() */
0x00, # 0x73 : distance threshold high LSB */
0x00, # 0x74 : distance threshold low MSB ( in mm, MSB+LSB), use SetD:tanceThreshold() */
0x00, # 0x75 : distance threshold low LSB */
0x00, # 0x76 : not user-modifiable */
0x01, # 0x77 : not user-modifiable */
0x0f, # 0x78 : not user-modifiable */
0x0d, # 0x79 : not user-modifiable */
0x0e, # 0x7a : not user-modifiable */
0x0e, # 0x7b : not user-modifiable */
0x00, # 0x7c : not user-modifiable */
0x00, # 0x7d : not user-modifiable */
0x02, # 0x7e : not user-modifiable */
0xc7, # 0x7f : ROI center, use SetROI() */
0xff, # 0x80 : XY ROI (X=Width, Y=Height), use SetROI() */
0x9B, # 0x81 : not user-modifiable */
0x00, # 0x82 : not user-modifiable */
0x00, # 0x83 : not user-modifiable */
0x00, # 0x84 : not user-modifiable */
0x01, # 0x85 : not user-modifiable */
0x01, # 0x86 : clear interrupt, use ClearInterrupt() */
0x40 # 0x87 : start ranging, use StartRanging() or StopRanging(), If you want an automatic start after VL53L1X_init() call, put 0x40 in location 0x87 */
class VL53L1X:
def __init__(self, i2c):
self.i2c = i2c
self.address = 0x29
self.reset()
utime.sleep(1)
if self.read_model_id() != 0xEACC:
raise RuntimeError('Failed to find expected ID register values. Check wiring!')
# write default configuration
self.i2c.writeto_mem(self.address, 0x2D, VL51L1X_DEFAULT_CONFIGURATION, addrsize=16)
utime.sleep(1)
# the API triggers this change in VL53L1_init_and_start_range() once a
# measurement is started; assumes MM1 and MM2 are disabled
self.writeReg16Bit(0x001E, self.readReg16Bit(0x0022) * 4)
utime.sleep(1)
def writeReg(self, reg, value):
return self.i2c.writeto_mem(self.address, reg, bytes([value]), addrsize=16)
def writeReg16Bit(self, reg, value):
return self.i2c.writeto_mem(self.address, reg, bytes([(value >> 8) & 0xFF, value & 0xFF]), addrsize=16)
def readReg(self, reg):
return self.i2c.readfrom_mem(self.address, reg, 1, addrsize=16)[0]
def readReg16Bit(self, reg):
data = self.i2c.readfrom_mem(self.address, reg, 2, addrsize=16)
return (data[0]<<8) + data[1]
def read_model_id(self):
return self.readReg16Bit(0x010F)
def reset(self):
self.writeReg(0x0000, 0x00)
utime.sleep(1)
self.writeReg(0x0000, 0x01)
def read(self):
data = self.i2c.readfrom_mem(self.address, 0x0089, 17, addrsize=16) # RESULT__RANGE_STATUS
range_status = data[0]
# report_status = data[1]
stream_count = data[2]
dss_actual_effective_spads_sd0 = (data[3]<<8) + data[4]
# peak_signal_count_rate_mcps_sd0 = (data[5]<<8) + data[6]
ambient_count_rate_mcps_sd0 = (data[7]<<8) + data[8]
# sigma_sd0 = (data[9]<<8) + data[10]
# phase_sd0 = (data[11]<<8) + data[12]
final_crosstalk_corrected_range_mm_sd0 = (data[13]<<8) + data[14]
peak_signal_count_rate_crosstalk_corrected_mcps_sd0 = (data[15]<<8) + data[16]
#status = None
#if range_status in (17, 2, 1, 3):
#status = "HardwareFail"
#elif range_status == 13:
#status = "MinRangeFail"
#elif range_status == 18:
#status = "SynchronizationInt"
#elif range_status == 5:
#status = "OutOfBoundsFail"
#elif range_status == 4:
#status = "SignalFail"
#elif range_status == 6:
#elif range_status == 7:
#status = "WrapTargetFail"
#elif range_status == 12:
#status = "XtalkSignalFail"
#elif range_status == 8:
#status = "RangeValidMinRangeClipped"
#elif range_status == 9:
#if stream_count == 0:
#status = "RangeValidNoWrapCheckFail"
#else:
#status = "OK"
return final_crosstalk_corrected_range_mm_sd0
def get_mm(self):
return test.read()
def get_in(self):
return test.read()*0.0393701
def get_ft(self):
return test.read()*0.0393701/12
i2c = I2C(0, freq=400000, sda=Pin(0), scl=Pin(1))
print(i2c.scan()[0])
test = VL53L1X(i2c)
print("OUTSIDE WHILE LOOP")
while(True):
print("Distance in mm: ", test.get_mm() )
print("Distance in in: ", test.get_in() )
print("Distance in feet: ", test.get_ft() )
utime.sleep(0.05)
