WLAN.ifconfig(
RobinMosedale
WLAN.ifconfig(
Post by RobinMosedale » Wed Feb 24, 2021 8:59 pm
It seems that setting the IP address of a Sta isn't available for the esp32 variant:
both variants of the syntax on the Micropython reference documentation (quick reference guide etc) raise errors
wlan.ifconfig(('192.168.1.144','255.255.255.0','192.168.1,254','192.168,1,254'))
wlan.ifconfig(config=('192.168.1.144','255.255.255.0','192.168.1,254','192.168,1,254'))
'ValueError: invalid arguments'
Am I correct that this is not available for Esp32, yet documentation implies that it does.
davef
Re: WLAN.ifconfig(
Post by davef » Wed Feb 24, 2021 10:02 pm
Try:
sta_if.ifconfig(('192.168.10.99', '255.255.255.0', '192.168.10.1', '192.168.10.1'))
Double brackets
RobinMosedale
Re: WLAN.ifconfig(
Post by RobinMosedale » Wed Feb 24, 2021 10:26 pm
Thank you Dave
RobinMosedale
Re: WLAN.ifconfig(
Post by RobinMosedale » Thu Feb 25, 2021 12:54 am
Isn't that identical to what I'm doing with merely a different instansiation of the wlan object name?
davef
Re: WLAN.ifconfig(
Post by davef » Thu Feb 25, 2021 12:58 am
Sorry, I don't know the reason ... I saw it somewhere when I had the same problem and it fixed it. I recall it has something to do with tuples.
RobinMosedale
Re: WLAN.ifconfig(
Post by RobinMosedale » Thu Feb 25, 2021 1:28 am
Very odd. Looks identical
Re: WLAN.ifconfig(
Post by jimmo » Thu Feb 25, 2021 2:23 am
In your example, you have commas instead of dots inside the last two addresses.
RobinMosedale
Re: WLAN.ifconfig(
Post by RobinMosedale » Thu Feb 25, 2021 3:29 pm
Forgive me Jimmo. I thought that I'd corrected those:-
However the alternative syntax doesn't work, but doesn't matter.
print(wlan.active(True))
wlan.config(dhcp_hostname='esp32cam')
wlan.connect("TP-LINK_EB850C","ju87bstuka")
print("Connected ",wlan.isconnected())
print(wlan.ifconfig())
Result:-
MicroPython v1.13-178-g21c293fbc-dirty on 2020-11-27; Camera Module (i2s) with ESP32
>>> import connect_ip2
True
File "connect_ip2.py", line 6, in <module>
TypeError: function doesn't take keyword arguments
Robin
Re: WLAN.ifconfig(
Post by jimmo » Thu Feb 25, 2021 11:54 pm
ifconfig doesn't take keyword argument.
You have
but it should be just
wlan.ifconfig(('192.168.1.144','255.255.255.0','192.168.1.254','192.168.1.254'))
What's going on here is that ipconfig takes a single (optional) argument. That argument is a tuple of ip/mask/gateway/dns.
It's clearer if you write it as
ip_config = ('192.168.1.144','255.255.255.0','192.168.1.254','192.168.1.254')
wlan.ifconfig(ip_config)
Note your code snippet also still has the commas in it.
