help with UART and Raspberry Pico
Donquizote99
Post by Donquizote99 » Wed Aug 18, 2021 8:40 am
Hello
I am developing a small personal project, I use raspberry pico and micropython, previously I had requested your help to solve some problems, despite obtaining the desired behavior, after a time "x" of execution (it varies the time) the program fails, however , it does not send an error, and the behavior of other tasks is not affected, the only task that stops working as expected is the one in charge of transmitting the data, I am a little lost, I do not know where I should look ...
comportamiento deseado:
falla:
the function in charge of transmitting the data:
async def dataout():
    uart = UART(0, baudrate=9600, tx=machine.Pin(16), rx=machine.Pin(17))
    swriter = uasyncio.StreamWriter(uart, {})
        d1 = await (h())
        d2 = await (t())
        d3 = await (humedadsustrato())
        d4 = await (tempico())
        d5 = await (tsustrato())
        if d1 == None:
            p1 = "xxxx"
            p1 = "{0:.3f}".format(d1)
        if d2 == None:
            p2 = "xxxx"
            p2 = "{0:.3f}".format( d2)
        if d3 == None:
            p3 = "xxxx"
            p3 = "{0:.3f}".format( d3)
        if estatus == True:
            p4 = "on"
            p4 = "of"
        if ledazul.pin.value() == 0:
            p5 = "aon"
            p5 = "aof"
        if ledblanco.pin.value() == 0:
            p6 = "bon"
            p6 = "bof"
        if ledrojo.pin.value() == 0:
            p7 = "ron"
            p7 = "rof"
        if bomba1.pin.value() == 0:
            p8 = "xon"
            p8 = "xof"
        p9 = "{0:.3f}".format( d4)
        if d5 == None:
            p10 = "xxxx"
            p10 = "{0:.3f}".format(d5)
        data_send =str("a"+p1+"b"+p2+"c"+p3+"d"+p4+"e"+p5+"g"+p6+"h"+p7+"i"+p8+"j"+p9+"k"+p10+"l")
        swriter.write(data_send)
        await swriter.drain()
        await uasyncio.sleep(2)
the function in charge of receiving the data is very simple:
ser = serial.Serial('/dev/rfcomm99', 9600,timeout=3, parity=serial.PARITY_EVEN, rtscts=1)
    if recibir == True:
        linem = ser.readline()
        line = linem.decode()
        indice_a = line.find("a")
        indice_b = line.find("b")
        indice_c = line.find("c")
        indice_d = line.find("d")
        indice_e = line.find("e")
        indice_g = line.find("g")
        indice_h = line.find("h")
        indice_i = line.find("i")
        indice_j = line.find("j")
        indice_k = line.find("k")
        indice_l = line.find("l")
        humedad_ambiente = line[indice_a+1:indice_b]
        temperatura_ambiente = line[indice_b+1:indice_c]
        humedad_sustrato = line[indice_c+1:indice_d]
        estatus_temp = line[indice_d+1:indice_e]
        azul = line[indice_e+2:indice_g]
        blanco = line[indice_g+2:indice_h]
        rojo = line[indice_h+2:indice_i]
        bomba = line[indice_i+2:indice_j]
        tempico = line[indice_j+1:indice_k]
        tsustrato = line[indice_k+1:indice_l]
        print("DATA:  "+line)
        print("---------------------")
        print("estaus temporizador: ", estatus_temp)
        print("azul: ", azul)
        print("blanco: ", blanco)
        print("rojo: ", rojo)
        print("bommba: ", bomba)
        print("humedad ambiente: ",humedad_ambiente)
        print("temperatura ambiente: ", temperatura_ambiente)
        print("temperatura sustrato: ", tsustrato)
        print("tem interna: ",tempico)
        print("humedad sustrato: ",humedad_sustrato)
        print("++++++++++++++++++++++")
        print("sin data para recibir")
    time.sleep(2)
Donquizote99
Re: help with UART and Raspberry Pico
Post by Donquizote99 » Wed Aug 18, 2021 9:01 am
Update:
I got the following error:
Task exception wasn't retrieved
future: <Task> coro= <generator object 'dataout' at 2000e610>
  File "uasyncio/core.py", line 1, in run_until_complete
  File "<stdin>", line 25, in dataout
  File "t_sustrato.py", line 18, in tsustrato
  File "ds18x20.py", line 40, in read_temp
  File "ds18x20.py", line 30, in read_scratch
Exception: CRC error
However I am just as lost, I suppose the failure in the data transmission is caused by a malfunction of the sensor code, looking a bit I found that it could be due to a false sense, however it causes me a conflict that works and stops working Any ideas where to look or how to fix this behavior?
import uasyncio
async def tsustrato():
        ow = onewire.OneWire(Pin(2))
            await uasyncio.sleep_ms(850)
            aa=(ds.read_temp(rom))
            return aa
        await uasyncio.sleep_ms(2000)
    except onewire.OneWireError:
        pass
    except TypeError:
        pass
    except KeyboardInterrupt:
        pass
robertcarell
Post by robertcarell » Thu Aug 19, 2021 1:12 am
So, we can upload micropython in Raspberry Pi Pico as well, I am new to micropython so just trying to understand it. I hope someone else will help you out.
