How to include driver into micropython compilation
vinz-uts
Re: How to include driver into micropython compilation
Post by vinz-uts » Mon Nov 15, 2021 1:32 pm
Hi, this is the files that you have to upload on the board. In the .zip archive there is also an example script that use ETH connection to require the current data from a NTP server. Best Regards.
wiznet5k.zip
Pure-python driver for WIZNET5K working on ESP32
(18.77 KiB) Downloaded 58303 times
neveregret
Post by neveregret » Mon Nov 15, 2021 1:49 pm
Can I use it with raspberry pi pico? Will it work?
vinz-uts
Post by vinz-uts » Mon Nov 15, 2021 3:31 pm
I think it will works with every board with the WIZNET5500 module connected via a machine.SPI. You can try if it works...
neveregret
Post by neveregret » Tue Nov 16, 2021 9:10 am
Hi, I tried with raspberry pi pico.It gives some error.When I run wiznet5k.py, it gives this:
  File "<stdin>", line 32, in <module>
  File "wiznet5k_dhcp.py", line 19, in <module>
  File "wiznet5k_socket.py", line 19, in <module>
  File "wiznet5k.py", line 33, in <module>
  File "wiznet5k_dns.py", line 20, in <module>
ImportError: can't import name htons
When I run wiznet5k_dhcp.py , wiznet5k_dns.py gives same error on different lines.
wiznet5k_socket.py doesn't gives error.
When I use your example code , I changed cs pin for my pico (I used wiznett w5500 with circuitpython same pin). It gives this:
  File "<stdin>", line 9, in <module>
  File "wiznet5k.py", line 159, in __init__
  File "wiznet5k.py", line 339, in _w5100_init
  File "wiznet5k.py", line 354, in detect_w5500
AssertionError: Expected 0x08.
When I added line 9 to bottom it gives this error:
  File "<stdin>", line 10, in <module>
  File "wiznet5k_socket.py", line 64, in getaddrinfo
  File "wiznet5k_socket.py", line 72, in gethostbyname
AttributeError: 'NoneType' object has no attribute 'get_host_by_name'
vinz-uts
Post by vinz-uts » Tue Nov 16, 2021 9:24 pm
For the `AssertionError: Expected 0x08.`, it seems is that the problem is in writing register on the chip. Are you sure your connected pin configuration is right. I had the same error when I had choose too high frequency for SPI. `htonl` and `htons` are function defined in `wiznet5k_socket`, so, if the import works, you have to be able to manually call these function.
neveregret
Post by neveregret » Wed Nov 17, 2021 5:50 am
I didn't set frequency, I tried with your example code (esp32_eth_wiznet5500_ntp).
I am using circuitpython like this,
spi_bus = busio.SPI(board.GP10, MOSI=board.GP11, MISO=board.GP12)
cs = digitalio.DigitalInOut(board.GP13)
I tried to write like this with micropython:
spi = SPI(1)
cs = Pin(13,Pin.OUT)
nic = WIZNET5K(spi,cs)
Only socket is not giving error.
wiznet5k_socket.py
import gc
import wiznet5k as wiznet5k
from micropython import const
When I import other modules on wiznet5k.socket.py (dhcp and dns) it gives 'ImportError: can't import name htons' error too. I guess I can't import them.I don't know why.
wiznet5k.socket.py :
import gc
import wiznet5k_dhcp as dhcp
import wiznet5k_dns as dns
_the_interface = None  # pylint: disable=invalid-name
irinakim
Post by irinakim » Thu Nov 18, 2021 7:35 am
from usocket import socket
from machine import Pin,SPI
import rp2
def main():
    spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
    nic = network.WIZNET5K(spi,Pin(17),Pin(20))
    nic.ifconfig(('192.168.100.20','255.255.255.0','192.168.100.1','8.8.8.8'))
        if nic.isconnected() == True:
            #print(nic.regs())
            s=socket()
            s.connect(('192.168.100.10',5000))
                data = s.recv(1500)
                print(data.decode('utf-8'))
                if data != 'NULL' :
                    s.send(data)
main()
github : https://github.com/irinakim12/micropyt ... e/wiznet5k
Loopback example : https://www.hackster.io/irinakim1225/ho ... hon-a6c351
steeley
Post by steeley » Sat Apr 16, 2022 4:55 pm
I've upload the directory to my esp32 - but it won't run because of this error:
ImportError: no module named 'wiznet5k.WIZNET5K'
I'm in the right directory.
How do I get it to work?
TIA
sepehr jami
Post by sepehr jami » Sun Apr 17, 2022 7:20 am
vinz-uts wrote:
Fri Nov 12, 2021 9:25 pm
Hi, I've done some test with a ESP32-WROVER-IE and an external SPI Wiznet5500 ethernet chip. After a lot of research on this forum and github, I've decided to try to modify a pure-python adafruit driver (developed for circuitpython) for this chip. Now it seems works, but maybe it need more test. I can share this driver if someone will try to use it, or, if someone help me to understand the right steps, I will upload it in the right folder of micropython repo.
hello sir. can you share it ?
vinz-uts
Post by vinz-uts » Wed May 11, 2022 11:10 am
Hi, this is the folder which contains the drivers files and the script test. You have to copy only the content of the folder (files, not the folder) in your micro and run the `esp32_eth_wiznet5500_ntp.py` file to try it. I've just tested it now and seems all works, I've also changed the NTP server with the google one. Let's me know if it works.
Best regards,
Vinz.
wiznet5k.zip
(18.57 KiB) Downloaded 57880 times
