Looking for suggestion on how to remove the header from Json string (line 21), or vice versa....
i'm using a Wave Pi Pico Evaluation Kit with Wave Pi Pico ESP8266 WiFi Expansion shown
below....
With much hair pulling I got this far, borrowing a snip bit or two from around the net...
I am tinkering with other options but no luck thus far...
Listing is shown below with it's resulting output...
import utime,time,sys
uart = UART(0,115200)
### WiFi Router ###
SSID='My_SSID'
password = 'My Pass Word'
### Json based Time server ###
ServerURL = 'worldtimeapi.org'
Port = '80'
### Write AT Commands to ESP8266
def sendCMD(cmd,ack,timeout=2000):
uart.write(cmd+'\r\n')
t = utime.ticks_ms()
while (utime.ticks_ms() - t) < timeout:
s=uart.read()
if(s != None):
s=s.decode()
print(s)
if(s.find(ack) >= 0):
return True
return False
### Necessary step, make sure that ESP8266 is in non transparent mode ###
uart.write('+++')
time.sleep(1)
### Necessary step before connecting to WiFi ###
### also dumping the header after restart ###
uart.write('AT+RST\r\n')
utime.sleep(1)
data = False
while data == False:
data = uart.any()
utime.sleep(1)
junk = bytearray(256)
morejunk = uart.readinto(junk)
### Setting up the ESP8266 WiFi router link and making ###
### connection and request to Json based time servar ###
sendCMD("AT","OK")
#sendCMD("AT+GMR","OK")
sendCMD("AT+CWMODE=1","OK")
sendCMD("AT+CWJAP=\""+SSID+"\",\""+password+"\"","OK",20000)
#sendCMD("AT+CIFSR","OK")
sendCMD("AT+CIPMUX=0","OK")
sendCMD("AT+CIPSTART=\"TCP\",\""+ServerURL+"\","+Port,"OK",20000)
sendCMD("AT+CIPSEND=115",">")
uart.write("GET /api/timezone/Africa/Johannesburg HTTP/1.1\r\nUser-Agent: curl/7.37.0\r\nHost: worldclockapi.com\r\nAccept: */*\r\n\r\n")
sendCMD("AT+CIPCLOSE","OK")
### Reading reply from Json based time server ###
### then exiting program ###
s=uart.read()
if(s != None):
s=s.decode('utf-8')
print(s)
if(uart.any() == 0):
sys.exit()
>>> %Run -c $EDITOR_CONTENT
AT
OK
AT+CWMODE=1
OK
AT+CWJAP="My_SSID","My Pass Word"
WIFI CONNECTED
WIFI GOT IP
OK
AT+CIPMUX=0
OK
AT+CIPSTART="TCP","worldtimeapi.org",80
CONNECT
OK
AT+CIPSEND=115
OK
+CIPCLOSE
busy s...
Recv 115 bytes
SEND OK
+IPD,980:HTTP/1.1 200 OK
access-control-allow-credentials: true
access-control-allow-origin: *
access-control-expose-headers:
cache-control: max-age=0, private, must-revalidate
content-length: 351
content-type: application/json; charset=utf-8
cross-origin-window-policy: deny
date: Sun, 12 Dec 2021 11:45:17 GMT
server: Fly/fb1a8b2 (2021-11-25)
x-content-type-options: nosniff
x-download-options: noopen
x-frame-options: SAMEORIGIN
x-permitted-cross-domain-policies: none
x-request-id: Fr__Ukvr0p3X5u-5l6kh
x-runtime: 287µs
x-xss-protection: 1; mode=block
via: 1.1 fly.io
fly-request-id: 01FPQ7C9CRXW05NTB3PJV9K7T8
{"abbreviation":"SAST","client_ip":"41.13.90.55","datetime":"2021-12-12T13:45:18.311653+02:00","day_of_week":0,"day_of_year":346,"dst":false,"dst_from":null,"dst_offset":0,"dst_until":null,"raw_offset":7200,"timezone":"Africa/Johannesburg","unixtime":1639309518,"utc_datetime":"2021-12-12T11:45:18.311653+00:00","utc_offset":"+02:00","week_number":49}
