It then waits for another input to go high for a few seconds (from a push button). If this happens, a traincoming led goes high.
The problem is that regardless of the state of the pushbutton, it constantly loops and I cant stop it. It should call the function, check if the pushbutton has been pushed in time, make sure it has been pushed for long enough and react either way and dont repeat until the toggle switch has another rising edge.
I am running this on a Pico.
Can anyone suggest why it is doing this?
def acceptance(Pin):
utime.sleep_ms(200)
timeoutflag = 0
print("accept")
start = time.ticks_ms()
while adjblockbell.value() == 0 and timeoutflag == 0:
if time.ticks_diff(time.ticks_ms(), start) > 5500:
print("TOO LONG")
timeoutflag = 1
if timeoutflag == 1:
return
while adjblockbell.value() == 1 and commutator.value() ==1:
if time.ticks_diff(time.ticks_ms(), start) > 4500:
led_traincoming.high()
led_normal.low()
return
