Hi all, i wish to assign a small int stack to be used ideally with queue or a list to rtc memory. Can anybody tell me please if assigning queue or a list to a specific memory address is possible. I wish to collect a small dataset that can survive a soft reboot without the need for additional hardware.
Thank you for your consideration.
Assign queue/list to rtc memory
Re: Assign queue/list to rtc memory
Have a look at https://github.com/karfas/upy-esp32-lib.
Most likely you will need to adapt this a little for the ESP8266 (I have no 8266 to test this).
A few hours of debugging might save you from minutes of reading the documentation!
Thank you karfas
