Hi guys,
I know, this is not really MicroPython specific, but as I use MiocroPython for all my sensors, I'll post ist here.
So I have several BME280 sensors. I gave up on the on-board temperature sensor, because this has a known issue self-heating and therefore always showing higher temperature values. I only want to use the air pressure sensor now:
I have two sensors outside, one of them measures 1029, the other 1031 and I think this slight difference is okay and within the tolerances. But now I checked the weather forecast and the current air pressure in my region is 1003. I know that air pressure given by the forecast is reduced to sea level, but I'm only 38m above see level. So in order to compensate my measurement I need to add (38/8 = 4.75 hPa) to my measurement which will give me aprox. 1035 hPa.
So the difference between the forecast and my measurement is (currently) around 32 hPa.
Unfortunately it's not a fixed difference.
I had a measured of 1077 which compensated to 1082 - the forecast at this time said it's 1035 which makes a difference of 47 hPa.
So anybody know how to successfully compensate the pressure sensor so that the readings makes any kind of sense?
Did I miss something here?
Thanks, Carsten
Compensate BME280 pressure measurements...
Re: Compensate BME280 pressure measurements...
Do not trust the weather forecast. Compare it to a known good value. I compared the BME280 and BME680 reading with the values published by the local University's lab figures and found them accurate within the specification.
Good point, but I check the values of various different sources - one from the "local airport" and one from "Meteorological institute of the free university of berlin" as well as the weather forecast. They all show the same value +/-2 hPa.
So unfortunately the problem still lays on my side.
Which library do you use? I made my tests with that one: https://github.com/robert-hh/BME280
Okay, never thought it could be a library thing. But I definitely used a different one. I'll make a test with the one you referenced above and see if this delivers different values...Roberthh wrote: ↑Tue Feb 01, 2022 11:19 amWhich library do you use? I made my tests with that one: https://github.com/robert-hh/BME280
