CANbus project question
ilium007
Post by ilium007 » Tue Apr 05, 2022 3:58 am
I am trying to get my CANbus project going and look at the Peter Hinch pushbutton asyncio class. I have two Adafruit STMF405's with CANbus transceivers connected and communicating.
UC1 is running the pushbutton class with a button and sending the CANbus msg:
import uasyncio as asyncio
from primitives import Pushbutton
from pyb import CAN
can1 = CAN(1, CAN.NORMAL, extframe=True)
buf = bytearray(1)
buf[0] = 0
msg_id = 123
def printmsg(msg):
    buf[0] += 1
    print('msg: {} count: {}'.format(msg,buf[0]))
    can1.send(msg, msg_id)
async def main():
    pin = Pin(Pin.cpu.C4, Pin.IN, Pin.PULL_UP)
    pb = Pushbutton(pin)
    pb.press_func(printmsg, ('push', ))
    #pb.long_func(printmsg, ('long',))
        await asyncio.sleep(60)       #keep the uasyncio loop alive
    asyncio.run(main())
except (KeyboardInterrupt, Exception) as e:
    print('Exception {} {}\n'.format(type(e).__name__, e))
#finally:
#    ret = asyncio.new_event_loop()  # Clear retained uasyncio state
UC2 is receiving and displaying:
import math, time
from pyb import Timer, Pin
from pyb import CAN
#lookup table for LED sin values
breath_lookup = []
def breath(x):
    return (0.5 + (0.5 * (math.sin(math.pi * x - (0.5 * math.pi)))))
for i in range(101):
    breath_lookup.append(breath(i/50)*100)
can1.setfilter(0,CAN.MASK32,0,(0,0))
buf = bytearray(8)
lst = [0, 0, 0, memoryview(buf)]
buf1 = bytearray(1)
buf1[0] = 0
def cb(bus, reason):
    if reason == 0:
        #print('pending')
        bus.recv(0, lst)
        buf1[0] += 1
        #print('msg: {} count: {}'.format(bytes(lst[3]), buf1[0]))
    if reason == 1:
        print('full')
    if reason == 2:
        print('overflow')
can1.rxcallback(0, cb)
tim = Timer(3, freq=1000)
ch1 = tim.channel(1, Timer.PWM, pin=Pin.cpu.C6, pulse_width=0)
async def breathe():
        for i in range(len(breath_lookup)):
            ch1.pulse_width_percent(breath_lookup[i])
            await asyncio.sleep_ms(30)
        await asyncio.sleep_ms(400)
async def main():
    count_old = 0
    asyncio.create_task(breathe())
        if buf1[0] != count_old:
            count_old = buf1[0]
        await asyncio.sleep_ms(0)       #keep the uasyncio loop alive
    asyncio.run(main())
#finally:
I noticed that occasionally UC2 can receive a string of 1 - 4 extra CANbus messages relating to button presses. The pushbutton class should apply a 50ms debounce so I don't see how these additional messages are being sent. As far as I can tell the only way it can occur is if the pushbutton instance sends the additional messages via the callback.
The below output shows an additional message (count: 251) that does not relate to a physical button press. The only way I can see that message being generated is by the pushbutton class callback:
UC1	                    UC2
msg: push count: 230	    msg: b'push' count: 230
msg: push count: 231	    msg: b'push' count: 231
msg: push count: 232	    msg: b'push' count: 232
msg: push count: 233	    msg: b'push' count: 233
msg: push count: 234	    msg: b'push' count: 234
msg: push count: 235	    msg: b'push' count: 235
msg: push count: 236	    msg: b'push' count: 236
msg: push count: 237	    msg: b'push' count: 237
msg: push count: 238	    msg: b'push' count: 238
msg: push count: 239	    msg: b'push' count: 239
msg: push count: 240	    msg: b'push' count: 240
msg: push count: 241	    msg: b'push' count: 241
msg: push count: 242	    msg: b'push' count: 242
msg: push count: 243	    msg: b'push' count: 243
msg: push count: 244	    msg: b'push' count: 244
msg: push count: 245	    msg: b'push' count: 245
msg: push count: 246	    msg: b'push' count: 246
msg: push count: 247	    msg: b'push' count: 247
msg: push count: 248	    msg: b'push' count: 248
msg: push count: 249	    msg: b'push' count: 249
msg: push count: 250	    msg: b'push' count: 250
	                    msg: b'push' count: 251
The other thing I am trying to understand is this error when i try to execute this:
from within the cb callback function:
    if reason == 0:
        #print('pending')
        bus.recv(0, lst)
        buf1[0] += 1
    if reason == 1:
        print('full')
    if reason == 2:
        print('overflow')
Error:
MPY: sync filesystems
MPY: soft reboot
uncaught exception in CAN(1) rx interrupt handler
MemoryError:
If I run the same line:
outside of the callback in async def main() it works fine.
ilium007
Re: CANbus project question
Post by ilium007 » Tue Apr 05, 2022 9:46 am
The project has been sitting on my desk running for the past 7 hours and I just pressed the button 5 times and it registered an additional 11 CANbus messages on the second microcontroller.
Screen Shot 2022-04-05 at 7.45.09 pm.png (262.02 KiB) Viewed 1665 times
ilium007
Post by ilium007 » Tue Apr 05, 2022 10:34 am
I noticed that the SN65HVD230 3.3 V CAN Transceiver breakout board that I'm prototyping with did not have bypass capacitors on the 3.3v pin. I placed a 100 nF cap on this pin and it seems to be working.
