file COPY on SD card
Good morning all,
I want to COPY (NOT move) a file on SD card from a working directory into an archive directory,
but I didn't find a copy command.
Maybe I searched in a wrong way, but I guess a file copy should be possible isn't it?
Thanky for any help
Klaus
Thanky for any help
Klaus
Re: file COPY on SD card
Where.did you expect a copy command. (Micro)Python is not a shell. You can easily create a copy command yourself. There is also a lib with sh like commands called upysh, which has a cp command for file copy.
Robert,
I thougt there is os.rename, os.remove, os.mkdir ... etc. available therefore also os.filecopy could be avalilable.
But I did as you suggested and coded the copy by myself (learned from the sh lib).
It works, but for bigger files it is to slow for me.
Therefore I changed to move the file by renaming it, which is much much faster.
Thanks a lot
Klaus
Thanks a lot
Klaus
renaming works only within a file system, not across file systems.
Yes that is the case in my project.
I only want to move from one directory to another.
So is there a way to copy a file from SD to another directory using one of the Python libs?
yes: upysh in micropython-lib
Nicolett,
here is my solution which I took from the lib upysh.
But a 1.5 Myte file takes time of nearly a minute, therefor I do a movement instead (takes time of a 1 second or less).
Best
Klaus
Best
Klaus
def copyfile(srcf, destf):
if srcf == destf:
print("Destination file must be different than source")
return
st = os.stat(srcf)
except:
print("'{}' not found".format(srcf))
return
st = os.stat(destf)
print("'{}' exists".format(destf))
return
except:
pass
fs = open(srcf, 'rb')
fd = open(destf, 'wb')
except:
fs.close()
print("Error opening '{}'".format(srcf))
return
print('3')
buf = fs.read(1024)
if len(buf) == 0:
break
fd.write(buf)
print('Fertig')
except:
fd.close()
os.remove(destf)
except:
pass
print("Error during copy")
fd.close()
fs.close()
except:
copyfile('/sd/DATALOG.csv', '/sd/Archiv/DATALOG123.csv')
If you look at upysh.py, you'll see that the copy operation uses a preallocated buffer and memoryview. That avoids the allocation during copy and speeds up the transfer. If you have sufficient memory, you could set the buffer size to 4096. That is the FAT block size and helps copying speed as well. A modified cp command from upysh would then be:
def cp(s, t):
if os.stat(t)[0] & 0x4000: # is directory
t = t.rstrip("/") + "/" + s
except OSError:
pass
buf = bytearray(4096)
buf_mv = memoryview(buf)
with open(s, "rb") as s, open(t, "wb") as t:
while (n := s.readinto(buf)) > 0:
t.write(buf_mv[:n])
