ESP-Now support for ESP32 (and ESP8266)
Lucje
Re: ESP-Now support for ESP32 (and ESP8266)
Post by Lucje » Sat May 21, 2022 10:43 am
davef wrote:
Thu May 19, 2022 10:57 am
I would not run a program like that in boot.py.
Leave boot.py with nothing in it.
In main.py
import my_program
in my_program.py put your wanted program.
Putting that code in boot.py and something goes wrong I am pretty certain that you will not be told what happened.
Tried it, doesn't make a difference.
Lucje
Post by Lucje » Sat May 21, 2022 10:44 am
In main.py
import my_program
Lucje
Post by Lucje » Sat May 21, 2022 11:15 am
In main.py
import my_program
This boot works very good, it tells you which program is currently running and if there is an error which program is at fault.
Lucje
Post by Lucje » Sat May 21, 2022 11:19 am
In case you were wondering what I'm making:
It's a remote control car. Why Wifi, just because it can ;)
Lucje
Post by Lucje » Sat May 21, 2022 1:09 pm
Apparently I only have to burn the firmware when I plug it in the computer.
It does al work fine as long I don't plug it in.
So guess it's not a big deal then :P
davef
Post by davef » Sat May 21, 2022 8:03 pm
OK, on your boot.py. I made one of these recently:
https://randomnerdtutorials.com/esp32-c ... eb-server/
with my grandson.
So, you believe your firmware is being corrupted or deleted when you plug it into the PC?
Lucje
Post by Lucje » Sun May 22, 2022 2:28 pm
with my grandson.
Cool, that was my first system for this little car. But my teacher wished there was communication between 2 Esp32. It was allowed to do this communication wired, but then it was quite a boring rc-car concept. I don't like easy and boring, so I had to challenge myself :D
Yes indeed.
In fact, I've noticed that if I unplug it while it's still on and plug it back in later (without turning it off, rebooting, or resetting) there's no problem. If I turn it off, reboot or reset, I have to re-burn it.
Furthermore, EspNow works very well and I will definitely recommend it to others who are ready (not everyone in my class is equally clever ;) )
davef
Post by davef » Sun May 22, 2022 8:47 pm
If you really want to get to the bottom of this problem ... is there a uPycraft forum? When I was looking around randomnerdtutorials I found a tutorial:
https://randomnerdtutorials.com/install ... tructions/
(be careful as it only works with 16.04 unless you compile yourself) with another link to:
https://randomnerdtutorials.com/flash-u ... 2-esp8266/
They seem to use the "boot" button in their process whereas on my system I use the EN button.
For a challenge grab a Linux PC install esptool and rshell and do it all from the command-line :)
Lucje
Post by Lucje » Thu May 26, 2022 2:53 pm
I don't think it the problem is uPycraft, I tried it with Thonny and I had the same problem.
But as it's an unknown problem I guess the problem might be this kind of board.
I have ordered an other typ, but as it is from AliExpress it will never be delivered in time. I'll have to use the ones I have.
And if it's the only problem and the rest does work fine, it want be a problem for the project after all.
I thank you all for the assistance.
(PS, I'm a windows guy, I'm not used to use command line (jet ;) ).)
Lucje
Post by Lucje » Thu May 26, 2022 3:01 pm
I've never had to use one of those buttons...
I tried it and it doesn't make any difference.
