Class destructor. Implementation error?
ajvperth
Post by ajvperth » Tue Jul 12, 2022 7:50 am
possibly I found an implementation error in micropython?
on CPython this code:
class Controller:
    def __init__(self):
        print('__init__()')
    def __del__(self):
        print('__del__()')
    def run(self):
        print('run()')
    Controller().run()
except KeyboardInterrupt:
    print('\nTerminated, Ctrl-C pressed')
except BaseException as exc:
    print('\nUnhandled exception : ', type(exc), exc)
prints: __init__() then run() and __del__()
on micropython: __init__() and run().
_del__() is missing?? --> the destructor is not called?
Re: Class destructor. Implementation error?
Post by jimmo » Tue Jul 12, 2022 9:19 am
This is a documented Micropython limitation:
https://docs.micropython.org/en/latest/ ... ed-classes
The additional overhead of tracking finalisation state for classes would be non-trivial. (We do this in a limited form for built-in types though)
Post by pythoncoder » Tue Jul 12, 2022 9:55 am
I've believe this is a limitation of CPython too - IIRC the destructor is not guaranteed to be called until you quit the interpreter. In a firmware "run forever" type application that equates to no guarantee at all.
ajvperth
Post by ajvperth » Tue Jul 12, 2022 11:14 am
Thanks, for pointing me to the page with core language limitations.
I did read it but did not realize the consequences.
