Small demo with two Pico HTTPS GET reuqests against the internet, with rxbuf=512:
Pico HTTPS GET through ESP01 serial2wifi
https://www.raspberrypi.org/forums/view ... 6&t=307704
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
webrepl_client.py
Re: Pico HTTPS GET through ESP01 serial2wifi
@robert-hh's pull request was worked on and merged 20h ago.
No need to build Micropython for robert-hh's configurable rx/tx buffers anymore.
Latest rp2 dailybuild from now on contains configurable UART buffers, here is latest:
https://micropython.org/resources/firmw ... ffda17.uf2
MPY: soft reboot
MicroPython v1.14 on 2021-04-13; Raspberry Pi Pico with RP2040
>>> from machine import UART
>>> uart=UART(0, 115200, rxbuf=512)
webrepl_client.py
webrepl_client.py
Howdy All
This seems pretty awesome. It seems like this file is the key:
I got 404 Not Found trying.
The postings here literally seems like the best option for uP http gets/etc..
Anyway, I was thinking the esp01 would be a logical choice to add to a micro board like the pico. But most of the internet web show how to run as a webserver - not an http client. I guess I don't really understand the intent of the esp01 if it only understand AT commands.
HermannSW was saying that this firmware fixed the issue (it's probably the first nightly build after that feature was added), but any _later_ version will work. Just use the 1.19.1 release -- https://micropython.org/download/rp2-pico/modulusmath wrote: ↑Wed Jul 20, 2022 3:14 amThis seems pretty awesome. It seems like this file is the key:
Right. Thanks for that. I thought followed up on all the threads.jimmo wrote: ↑Wed Jul 20, 2022 11:01 amHermannSW was saying that this firmware fixed the issue (it's probably the first nightly build after that feature was added), but any _later_ version will work. Just use the 1.19.1 release -- https://micropython.org/download/rp2-pico/modulusmath wrote: ↑Wed Jul 20, 2022 3:14 amThis seems pretty awesome. It seems like this file is the key:
For what it's worth, I'm able to connect to wifi and given an HTTP resource like neverssl, tcpdump shows me SYN/ACK, so I can send data with AT commands. However, (I am still pursing how to get the latest Firmware on the esp01, that seems like it could be a bit involved and trying to keep it simple w/o introducing TLS), it is at:
AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
compile time:May 20 2016 15:08:19
>>> uart0.write("http://splendidfinewonderouskiss.neverssl.com/online/" + "\n")
54
>>> print(uart0.read().decode())
ERROR
I'll keep pursuing this including the firmware upgrade...
