FreeDOS support
pfalcon
Re: FreeDOS support
Post by pfalcon » Sat Nov 28, 2015 5:15 pm
If you can polish that into clean patches, we'd be glad to merge them into mainline.
Awesome MicroPython list
josie87
Re: FreeDOS support
Post by josie87 » Mon Nov 30, 2015 2:09 pm
Great! You made it. Will test asap. :-)
pohmelie
Re: FreeDOS support
Post by pohmelie » Mon Nov 30, 2015 4:02 pm
pfalcon wrote:If you can polish that into clean patches, we'd be glad to merge them into mainline.
Do you mean pull request? How to be with binaries? Also, makefile copied from unix build, but, I think, it's dirty for FreeDos with unused parts and can be stripped. But I have no experience with makefiles at all :? And some *.c files (maybe another ones too) are not used, I think.
josie87 wrote:Will test asap
Awesome, feedback is what we need here, since it tested only with one board and dosbox.
pfalcon
Re: FreeDOS support
Post by pfalcon » Mon Nov 30, 2015 4:11 pm
Yes.
The simplest answer - in no way. Users who need it, can build it themselves. There's also ticket to provide binaries in "official" way: https://github.com/micropython/micropython/issues/1295 , but it likely will take a lot of time to get that done. You of course can provide binaries yourself, at your, and your users risk.
So, ideal solution would be to just use existing unix makefile and port directory (and just apply as few as possible #ifdef's to support DJGPP). If that's not possible, then having a top-level directory with minimal set of files, like for Windows, would work too.
Re: FreeDOS support
Post by dhylands » Mon Nov 30, 2015 5:01 pm
I'd be more than happy to help you with any makefile stuff that's needed.
pohmelie
Re: FreeDOS support
Post by pohmelie » Mon Nov 30, 2015 10:15 pm
pfalcon wrote:ideal solution would be to just use existing unix makefile and port directory
Are you sure this is the best solution? Cause I think, that FreeDos have very little with unix build, not about Makefile difference, but… this is very different operating systems. I think more, than win and unix are. Also, FreeDos build requires proper environment variables, so there should be readme/guide, something like in my repo right now. So it's not just easy as "make freedos".
dhylands wrote:I'd be more than happy to help you with any makefile stuff that's needed.
Awesome, I will try to minimize port and will post progress here, so you can review it. ;)
Re: FreeDOS support
Post by dhylands » Mon Nov 30, 2015 10:26 pm
In terms of reviewing things, the best (for me) would be to put the changes on a github branch and post a link to your branch.
pohmelie
Re: FreeDOS support
Post by pohmelie » Mon Nov 30, 2015 10:53 pm
Of course, I need time to try minimize repo.
pohmelie
Re: FreeDOS support
Post by pohmelie » Tue Dec 01, 2015 8:10 am
I'm done with minimizing as I can. I think you can review it now ;) https://github.com/pohmelie/micropython ... er/freedos
There is some «trick» to avoid alloca.h, for example. I use -D__FreeBSD__=5 cause -DMICROPY_NO_ALLOCA=1 does not work. Hm, but probably we can just remove those #if #else #end and just #include <stdlib.h> at the end of mpconfigport.h.
josie87
Re: FreeDOS support
Post by josie87 » Tue Dec 01, 2015 11:32 am
Followed the instructions so far. DJGPP builds without errors.
Getting an error while building the Freedos port:
/home/johannes/djgpp/lib/gcc/i586-pc-msdosdjgpp/4.9.3/include/stddef.h:56:24: fatal error: sys/_types.h: No such file or directory
#include <sys/_types.h>
compilation terminated.
Used this env setting:
export CROSS_COMPILE=/home/johannes/djgpp/i586-pc-msdosdjgpp/bin/
export DJGPP_GCC=/home/johannes/djgpp/bin/i586-pc-msdosdjgpp-gcc
make
screenshot:
Bildschirmfoto von »2015-12-01 12-29-13«.png (70.05 KiB) Viewed 9296 times
