SPI not working
PCA
SPI not working
Post by PCA » Sat Jan 23, 2016 8:54 pm
Hello, trying to connect an SPI device.
using GP14, GP15, GP16 as SCLK, MOSI, MISO.
from machine import SPI
spi = SPI(0, SPI.MASTER, baudrate=2000000, polarity=0, phase=0, firstbit=SPI.MSB)
for i in range(3) :
    mydata = bytearray([1,2,3,4])
    spi.write(mydata)
    time.sleep(2)
checked with a scope :
MOSI seems OK but no activity on SCLK (High level)
tried to add a pull up/down resistor : no change
firmware is v1.5.2-71-gcb4fbc8
no more idea ...
Can you help ?
Pascal
danicampora
Re: SPI not working
Post by danicampora » Sat Jan 23, 2016 9:10 pm
I see that this is missing from the docs. The default SPI pins are GP14, GP16 and GP30. In order to select other pins you need to add the 'pins' tuple to the constructor:
spi.init(mode, baudrate=1000000, *, polarity=0, phase=0, bits=8, firstbit=SPI.MSB, pins=(CLK, MOSI, MISO))
Example:
spi = SPI(0, SPI.MASTER, baudrate=2000000, polarity=0, phase=0, firstbit=SPI.MSB, pins=('GP14', 'GP16', 'GP15'))
The PinOUT is here: https://raw.githubusercontent.com/wipy/ ... PinOUT.png
Cheers,
Daniel
PCA
Re: SPI not working
Post by PCA » Sat Jan 23, 2016 9:33 pm
Hi Daniel, thank you for the ultra fast answer!
Unhappily the issue is not solved.
My new code :
cs = Pin('GP17',mode=Pin.ALT, alt = 7)
spi = SPI(0, SPI.MASTER, baudrate=200000, polarity=0, phase=0, firstbit=SPI.MSB, pins=('GP14', 'GP16', 'GP15'))
for i in range(3) :
    spi.write(mydata)
    time.sleep(2)
MOSI is OK. CS is OK (due to my line cs = Pin('GP17'... ))
But GP14 (SCLK) always stuck high.
I checked the GP30 pin : no activity.
Pascal
PCA
Re: SPI not working
Post by PCA » Sat Jan 23, 2016 9:36 pm
Daniel,
mistake : GP30 is MISO (by default) so an input. no activity is just normal...
ignore my remark on this point.
Pascal
PCA
Re: SPI not working
Post by PCA » Tue Jan 26, 2016 1:11 pm
@danicampora
I suspect an hardware problem on my Wipy module.
I've just ordered a new one and will test again as soon as it arrives.
Pascal
