as a systems admin kind of guy. when I create a firmware with frozen code I get the boot text with the build number that I built my code from so I can't tell after it loaded on a board that it contains my frozen code without doing an import.
So my questions are
1. Is bad form for me to change the boot text before I build the bin file?
2. if not where is that text stored in the git repo that gets baked into the bin?
Hal
Frozen code images change version on esp8266
Re: Frozen code images change version on esp8266
I appreciate this doesn't actually answer your question, but issuing help('modules') will list your frozen modules along with others which are available.
no that was not the question but very helpful.
thanks.
Hal
thanks.
Hal
Indeed, very interesting.help('modules') will list your frozen modules
At risk of stating the obvious (and again failing to answer the question
) a solution to the problem in the OP might be as follows. For each project put a file "project_list.py" in the project's frozen modules directory. This would simply contain print statements describing the build. On all boards main.py would then do something like
import project_list
except ImportError:
print('Standard build.')
