Frozen code images change version on esp8266
thetreerat
Post by thetreerat » Tue May 02, 2017 2:23 pm
as a systems admin kind of guy. when I create a firmware with frozen code I get the boot text with the build number that I built my code from so I can't tell after it loaded on a board that it contains my frozen code without doing an import.
So my questions are
1. Is bad form for me to change the boot text before I build the bin file?
2. if not where is that text stored in the git repo that gets baked into the bin?
Hal
Re: Frozen code images change version on esp8266
Post by pythoncoder » Tue May 02, 2017 4:00 pm
I appreciate this doesn't actually answer your question, but issuing help('modules') will list your frozen modules along with others which are available.
thetreerat
Post by thetreerat » Tue May 02, 2017 6:12 pm
no that was not the question but very helpful.
thanks.
Hal
Post by Roberthh » Wed May 03, 2017 5:43 am
Indeed, very interesting.
Post by pythoncoder » Wed May 03, 2017 6:39 am
At risk of stating the obvious (and again failing to answer the question ;)) a solution to the problem in the OP might be as follows. For each project put a file "project_list.py" in the project's frozen modules directory. This would simply contain print statements describing the build. On all boards main.py would then do something like
    import project_list
except ImportError:
    print('Standard build.')
